Restore engine additive.
Not too sure if this is the right thread for this..
I was at Autozone the other day and I saw this restore stuff that you can put in your motor to "restore the compression and performance."
http://www.restoreusa.com/Engine_Restorer.html
I remember I put this stuff in my old Saturn SL a long time ago, and from what I remember it actually helped considering it had over 300k miles on it.
Anyone have any feedback on this stuff? I might try it on my LS swapped EK, because the motor was previously boosted, and last time I checked, my compression was at 145,145,146,147.
If I do end up doing it, I will do some compression checks before and after to see the effects. Just curious if there's any negative side effects.
Re: Restore engine additive.
It's hard to put much faith in a repair in a can, but if you're just trying to get by a little longer, or planning on a rebuild anyway, it couldn't hurt. Since you've got before numbers, this would be a good experiment. I'd be interested to see if it actually restores compression.
I used it year after year on my y8 in my coupe. it actually did me some good as far as compresion goes (sorry cant give numbers, over 5 yrs ago) & never had a problem with it, just follow the can and change oil again after 1.5k
its more of a prevenative product, its not gonna fix any real problems going on but can help, at least it did for me
efking1985
07-26-2007 07:13 PM
