my eg lights wont work
so i was drivin around the other day and my rpm cluster and signals stopped workin, rpm gas, temp all dont work, i checked all the fuses all of them are good,
anyone have any ideas?
Re: my eg lights wont work
dont visually check ur fuses use a fuse tester sometimes they might look ok but they are not they are from 92-95 so could be corroded also make sure to check your grounds but somnds like its a fuse that popped under the hood or under the dash
quick question for ya. this happened to me (headlights and cluster lights going out) bought a new 30amp fuse and it blew. decided to just go to a 40amp fuse. it's holding up great. but i know it's not the best idea to up the amperage on fuses. so basically my question is, what grounds should i check??
if you got a friend with another eg, try to swap his headlight combination switch with yours and see if it works, if you don't have an extra to swap, take yours apart and clean the metal contact points
thats only if the lights in the cluster don't work, if the gauges don't move however, check all your fuses following the procedure in post 4
cleanda6
10-29-2011 09:08 PM
94BlackEX
06-17-2004 01:31 AM
1sikcoupe
10
05-07-2004 03:23 PM
