Which fuel regulator for all motor LS?
I'm currently in a debate between the B&M Command Flow and the Blox fuel pressure regulators. Please only comment if you have had experience with either. I'm also leaning toward not even getting an adjustable regulator, since it will not yield many horses. Thanks for the input.
Re: Which fuel regulator for all motor LS?
You shoudnt install a fuel pressure regulator unless you are running a bigger fuel pump and bigger injectors and it calls for the fuel pressure to be adjusted during tuneing. If your doing fine on stock psi then there is no need for a fpr.
those are both junk if u wanna fuel pressure regulator get an aeromotive. as you noted yourself it wont net any gains or make it run any better. do not install one unless its necessary.
02 Civic SI 865
12-20-2006 02:19 PM
