99 Civic hatch/98 B18C swap/P28 ECU/OBD1-2 jumper harness - cranks but won't start
i need help and i noticed the underdash harness are missing a few wires, but everything is plug and play. it cranks but its not giving enough juice to start the gsr..i was just wondering if i need to add or jump any harness..the set up is B18C engine with a 00 em1 engine harness witha p28ecu but has a jumper harness from a OBD2 to OBD1..please help thank you..
Crazy Honda Guy
Re: B18C into EK9 help
You could have a problem elsewhere . You says it cranks right? What do you mean, "its not giving enough juice to start the car"? Check and make sure you are getting fuel and spark. Also make sure you did not cross the connectors for the map sensor and iacv because it is a common mistake.
its a 98 p72 well thats what my nephew told me because im using his. it cranks up yes but it doesn't start. sounds like its dying. all of the wiring to the motor are connected correctly..but i was just wondering if the dash harness are different and if i need to change that out. thanks for your replies
ek coupe dash harness and ek hatch dash harness..they are different. because i do have both car at my house right now. i know i can swap dash harness just wondering if there's a easier solution.
its way to much work to take it out and what if you doesn't fit correctly? 96-98 climate control and 99-00 climate control are different too so im kinda iffy about doing that..im just waiting on a sunny day to i can just open up the engine harness and reattach the wiring but not sure if thats a good idea or not either. thats why im asking
im missing wires from under the dash harness not the motor harness..ek hatchies have 2 harness that connects to 1. the engine harness 2. to the ecu but then again the b16 harness has 4 connector 1. 3 harness connects to the ecu 2. connects to the green (under dash harness). i know its a wiring problem NOT the motor..just need some help
I didn't see that you said the other car was 99-00 civic till now. But like you said the cabin harness is probably different being that is obd2b and the different climate control setup. I would make sure you are getting fuel and spark and all your connections are correct first.
What year is the car the gsr motor going into?
the 98gsr is going into the 99 ekhatchie
crazy that if i put it in my ek ex coupe it'll plug right in and i wouldn't have this problem..i guess im gonna have to look for a 99-00 ex coupe under dash harness smh* no easier solution =(
i'm confused. what year is your hatchback? if it's a 96-98, use a 96-98 harness and modify whatever you need to. an ex harness will make it a lot easier, but your stock non-vtec will work also.
