Please Help! D16Y8 Hesitation & Bogging
Old 11-17-2011, 06:34 PM
luffy's Avatar
Default Please Help! D16Y8 Hesitation & Bogging
So here goes, I've been reading / searching etc. for the past 2 months, so bear with me.
The Car:
1998 Civic Si (canadian edition) 5spd, No A/C, 170k km / 110k miles. Stock everything.
The Problem:
When cold ---> the car is generally fine, quick starts and no real issues to speak of.
When warmed up
- Fluctuating idle when stopped, almost to the point of stalling
- At speed, when applying light throttle, car will drive normally. Revving freely up to 6k+.
- At speed, when applying a reasonable amount of throttle, the car will "stutter" or hesitate. If you stay into the throttle, the car will shudder more and throw a P300,301,302 & P1399 code.
What I've done
- Replaced spark plugs (twice, with factory NGK & bosch)
- Replaced ignition wires (NGK blues)
- Replaced cap & rotor
- Swapped distributor and resistance checked 3 sensors (all are ~350 ohms)
- Replaced ignition coil
- Replaced PCV valve
- Cleaned throttle body
- Replace air, oil and fuel filter.
- Checked for intake/ vaccuum leaks
- Adjusted / Calibrated TPS sensor
- Cleaned IACV
- Cursed the thing and contemplated rolling it into a lake...
I'm starting to think my cat might be plugged up, does anybody see something I'm missing?
Any help would be greatly appreciated!
-Adam
Old 11-17-2011, 08:19 PM
BaronvonOttobat's Avatar
Default Re: Please Help! D16Y8 Hesitation & Bogging
I'd check your MAP sensor, get one from a junkyard, auto stores usually charge around 80 for one.
Old 11-17-2011, 09:10 PM
Kohen's Avatar
check the timing
Old 11-18-2011, 03:15 AM
quick86's Avatar
Check your primary O2 sensor as well. Mine had a hesitation/stumble and it was just a wasted O2 sensor. Mine never threw a code though.....Replaced it and it made a WORLD of difference. I even picked up like 3mpg...
Old 11-18-2011, 04:21 AM
luffy's Avatar
Should have mentioned it,
I had changed the O2 sensor and it had no effect.
-Adam
Old 11-18-2011, 07:06 AM
motegicivic's Avatar
Try cleaning your IACV as well.
Also, are there NGK plugs in now? Check the gap.
Old 11-18-2011, 07:33 AM
Retired Moderator
EsotericImage's Avatar
might be the cat as well..
Old 11-21-2011, 10:19 AM
luffy's Avatar
Cleaned the IACV, adjusted the TPS within spec. No change, problem persists.
Map sensor looked clean and tested fine.
Plugs have been gapped.
-Adam
greymouser7
06-14-2018 03:12 AM
physSix
08-14-2014 07:41 PM
Cartwright
10
07-25-2010 05:59 PM
theelemental
11-07-2008 01:37 PM
Xion
17
05-19-2006 05:15 PM
Quick Reply: Please Help! D16Y8 Hesitation & Bogging
