No electrical power help
Replaced alternator and I have 0 power no lights. Nothing I'm working on it ATM if u got something and I took off the positive cable when I was working not the negative ....
Re: No power help
I hooked the battery charger up it doesn't look to be full charged I think I should start tere I guess but I figured I'd still get the lights in the dash to come on since it did when it die over night hmmm
Re: No power help
you must of touched something else than the valvecover i had thesame thing happen to my car the ground for some reason F-d up and i had to sand part of the paint off and now it works and it just did it randomly
Re: No power help
nothing it was random i parked the car came out 2 hours later thought my battery died my friend jumped it for 30 minutes nothing at all came on i pushed down on the battery ground and the car started working inside so i removed my fusebox sanded down a little area and put my ground under the fusebox screwholes the battery ground would be a perfect explenation why nothing is working also the battery fuse
Re: No power help
ill re check the ground 2 maro and the battery fuse looked good u can tell if its bad just by looking at it correct since it has a see through top?
Re: No power help
Please create more descriptive thread titles. "No power" could mean a lot of different things. You meant no electrical power. Title edited.
Test the 80A hood fuse.
And buy an inexpensive multimeter.
Re: No power help
Re: No electrical power help
soundsl ike a grounding issue.
Multimeters are only a few $ at harbor freight, and they arent even expensive at major retailers anymore
2 dollars lol thats a little costly ima get one from a local store so i can use it today but i didnt know harborfreight was online thank you!~
