how to tighten crank pulley bolt on automatic SOHC?
it says to torque the bolt to 134 ft/lb. I got on it some w/ an impact wrench but I was gonna check it with a torque wrench to see how tight i got it. I can not figure out how to keep the pulley from turning when I am checking it w/ the torque wrench. I have tried it w/ the tranny in P and D, and tried sticking something in the cam gear to keep it from turning but changed my mind on that because it probably was not meant to have 134 ft/lb of pressure on it. How can I keep the crankshaft from moving on an auto?
thanks
thanks
Risky Business
Re: how to tighten crank pulley bolt on automatic SOHC? (teal_dx)
when i did my mini me...we just used our impact wrench...we had like 90psi because the tank wouldnt hold air...but it was fine...
Re: how to tighten crank pulley bolt on automatic SOHC? (BauleyCivic)
thats what i did the last time I had mine off (when i was doing the mini-me too) and 3 weeks ago the crank pulley came off on the road
want to be sure that never happens again!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teal_dx »</TD></TR><TR><TD CLASS="quote">thats what i did the last time I had mine off (when i was doing the mini-me too) and 3 weeks ago the crank pulley came off on the road
want to be sure that never happens again!!</TD></TR></TABLE>
Had the same damn thing happen to me after changing my timing belt...talk about sucking!! I payed Honda like 12 bucks for a new bolt and keyway!
Re: how to tighten crank pulley bolt on automatic SOHC? (rob d)
that tool might work for stock pulley, but after mine came off I replaced it w/ an underdrive (a new one from is $130 )
bradley
13
01-09-2012 02:12 PM
Nocturnal
08-07-2005 07:21 PM
