Motor swap??
Motor swap??
Hey guys whats up? Ok check this it....is there a way to swap a motor without a motor hoist...all that is left under my hood is the bottom end and tranny...cant i put something under the tranny and bottom end to hold it up till i can undo all the bolts and pull it out with some friends? i really wanna get my car running again....thanks!
Leroy
Leroy
Re: Motor swap?? (SpyderZEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX »</TD></TR><TR><TD CLASS="quote">I rented one for $30 when I did my swap. You WILL definately want one.</TD></TR></TABLE>
exactly. but if you really have to do it without it, jack the front of the car way up in the air and put it in from the bottom with a heavy duty floor jack. it wont be easy, but it can be done. id just go and rent a hoist. it will be way easier
Re: Motor swap?? (jeremyEG)
i did 2 complete b16 swaps in a crx (tight fit) from the bottom end. never did a swap using a hoist. had 2 people lift the car from the sides and slid it from the bottom
Re: Motor swap?? (b16hf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hf »</TD></TR><TR><TD CLASS="quote">i did 2 complete b16 swaps in a crx (tight fit) from the bottom end. never did a swap using a hoist. had 2 people lift the car from the sides and slid it from the bottom</TD></TR></TABLE>
did u do that putting the motors in also?
Re: Motor swap?? (mugensport9)
yes i took the motor out from the bottom and soon as u pulled it out i slid the new one in and dropped the car down onto the motor....very simple. i was suprised how easy it is. i have a hoist at my girlfriends but it was not needed. never used a hoist so i cant tell you which was easier but a b16 is a tight fit in the crx and i found it to be very easy
Skeletor
85
06-29-2004 09:56 AM
