JDM D15b vtec parts? Please help.
I need to know the part numbers for these from Autozone, Discount Auto Parts, Pep Boys, or someplace like that. This is for a (grey plug..OBD-1)JDM D15b vtec engine and tranny.
spark plugs
spark plug wires
water pump
timing belt
clutch assembly
flywheel
Thanks!
spark plugs
spark plug wires
water pump
timing belt
clutch assembly
flywheel
Thanks!
Re: JDM D15b vtec parts? Please help. (1990hondaHF)
im pretty sure the clutch, flywheel, spark plugs and wires would all be d16z6 spec. i could only guess the timing belt and water pump are the same. you could always pull off the timing belt and water pump and compare them to d16z6 parts at the store
Re: JDM D15b vtec parts? Please help. (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">im pretty sure the clutch, flywheel, spark plugs and wires would all be d16z6 spec. i could only guess the timing belt and water pump are the same. you could always pull off the timing belt and water pump and compare them to d16z6 parts at the store</TD></TR></TABLE> <U></U>
confirmed
confirmed
hondur
01-16-2017 09:58 AM
SharkEg
04-17-2012 04:08 PM
