still having problems
well i have come to the conclusion that either my master cylinder or slave cylinder has gone out. i bled the system and it is still not right, no how can i tell if it is the master or the slave going out. thanks
Re: still having problems (95civicracer)
When a hydro clutch system goes out, 95% of the time you will see a leak. When you mash the pedal, the piston either shoves fluid down the line or it goes around the piston and leaks into the inside of the car. If it goes down the line either it moves the throw out fork or it leaks around the piston down there. If it is giong around the piston at the slave, (with the way honda covers the lever on the fork) it could be leaking into the dust boot, running down the inside of the trans bell, and dripping out the little drain slot on the bottom of the trans. It could also be air or moisture in the fluid in the lines. It could also be, the tip of the slave cylinder is slipping outta the dimple on the end of the throw out fork. Pull dust cover back and look for fluid or the end of the slave sitting funny. If you see nothing there, bleed the crap outta the lines (new fluid from one end to the other). Look to make sure nothing has pinched any of the lines (even under the battery tray).
Johnmadsen
04-15-2018 03:16 PM
FRKWOO
12
05-19-2009 04:25 PM
