99-00 front si sway bar.
New User
so i have a 22m bar in the front and about to get a si bar. now will the d bracket from
the si bar mount up where my 22mm bar is right now? or do i need a new cross member.
anyone have pics of the 22mm bushings and 26mm bushing?
thanks
thanks
I dont have picture of the bushings........But if yuo plan on using a 99-00 Civic Si front sway bar you will have to change control arms......the way the sway bar attaches to the LCA is different from EX to Si
New User
Re: (NAEBP00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAEBP00Si »</TD></TR><TR><TD CLASS="quote">I dont have picture of the bushings........But if yuo plan on using a 99-00 Civic Si front sway bar you will have to change control arms......the way the sway bar attaches to the LCA is different from EX to Si</TD></TR></TABLE>
actully i dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackson »</TD></TR><TR><TD CLASS="quote">The holes on the subframe will line up with the si bar. I'm assuming you are talking about that.</TD></TR></TABLE>
yea kinda. so the "D" bracket that holds the bushing will fit or line up with the holes
that hold the 22mm bracket right?
actully i dont.
Re: (Mr. Choi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi »</TD></TR><TR><TD CLASS="quote">
actully i dont.
that hold the 22mm bracket right?</TD></TR></TABLE>
yes, they will line up. If you do have to get new lower SI control arms, your gonna need new forks too.
actully i dont.
Re: (Peagreenhatch)
It's probably better to get get the entire Si front suspension conversion with the LCAs and forks since the Si LCAs are lighter and stronger (I think, can anybody confirm this?).
Also, does the Si LCAs and forks cause the front end to sit higher, lower, or would the front height be unaffected? Visually, the Si LCAs look differently from those of the EX, but is the geometry the same?
