Pos engine still not starting
Re: Pos engine still not starting (RuthlessEj6)
Ok keep me posted on this. No spark, no fuel pump priming = bad ECU, bad jumper harness, OR the main relay screwed.
First of all, with the key in the ON position.......does the CEL go on for 2 seconds then go off, or does it just stay on the whole time?
Check the ECU fuse, ECU back up fuse, (both under the hood) and the ACG fuse (next to the SRS fuse under the dash).
In The Garage
Re: Pos engine still not starting (poison)
also, you need to run B-series injectors and fuel pump. sounds like possibly a ground problem, and maybe a bad main relay. do you have powa to the main relay?
edit- also, you don't need to check injectors for voltage, you need to check for pulse. injectors usually get ~10.x volts. do you have a spark?
Location: Your really lame if you dock my points, WA, 98033
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Ok keep me posted on this. No spark, no fuel pump priming = bad ECU, bad jumper harness, OR the main relay screwed.
Check the ECU fuse, ECU back up fuse, (both under the hood) and the ACG fuse (next to the SRS fuse under the dash).</TD></TR></TABLE>
we checked mainrelay and that was fine. even replaced it with a buddy of mines who has a 96 cx.
when the car is turned to the on postion the engine light stays on the whole time.
the car has spark and is now getting fuel cause we wired the fuel pump to the ignition before it wasnt getting any power at all.
Ok, the CEL should come on and go off after 2 seconds. Check the ACG fuse next to the SRS fuse under the dash.
In The Garage
ok, well you need some injectors out of something like a B16A3, 94-95 B18B1, 94-95 B18C1, etc. also, make SURE the ecu is grounded. the ground is under the hood, at the thermostat housing (back of the block, where lower radiator hose connects)
Re: Pos engine still not starting (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R »</TD></TR><TR><TD CLASS="quote">ok, well you need some injectors out of something like a B16A3, 94-95 B18B1, 94-95 B18C1, etc. also, make SURE the ecu is grounded. the ground is under the hood, at the thermostat housing (back of the block, where lower radiator hose connects)</TD></TR></TABLE>
good point, AND the tranny ground secure
so are you saying the d series injectors will not work??? ive been told here on honda tech that b series and d series injectors are the same and flow at 240cc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuthlessEj6 »</TD></TR><TR><TD CLASS="quote">so are you saying the d series injectors will not work??? ive been told here on honda tech that b series and d series injectors are the same and flow at 240cc. </TD></TR></TABLE>
I have heard that, but I've always converted the harness to use the B series injectors.
In The Garage
well, my friend brian (Plan B on here, knows his ****) had d-series injectors on his built gs-r, and it ran like ****. (the car has 12.5:1 cr) he put in 99-00 Si injectors, and it runs awesome.
edit- note- it will run with d-series, though. look for a ground/relay/sensor/ecu problem
Re: (22lbGS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22lbGS-R »</TD></TR><TR><TD CLASS="quote">well, my friend brian (Plan B on here, knows his ****) had d-series injectors on his built gs-r, and it ran like ****. (the car has 12.5:1 cr) he put in 99-00 Si injectors, and it runs awesome.
edit- note- it will run with d-series, though. look for a ground/relay/sensor/ecu problem</TD></TR></TABLE>
lol ya. I just always used the B series, but if it'll work good
good pointers bro
good pointers bro
Re: (poison)
i plan on using b series injectors. i just want to get the motor started first.
quick question i checked for the ACG fuse and couldnt locate it. what does ACG stand for?
Re: (RuthlessEj6)
It's next to the SRS fuse. This completes the circuit with the main relay/ecu.
I remember seeing what ACG stands for according to Helms a while back, but I can't friggin remember, now you're killing me!
it'll hit me eventually lol
Re: (poison)
dont worry it will probably come to you when your not thinking about it.
i just thought of somethign that it could possibly be. i had to rewire my distrbutor
beacause it didnt plug up to my harness. the distributor was off a obd2b engine,
so we cut the plug off and used the plug of my d16 and color matched the wires
and used but connectors. on the hybrid forum on ht i posted this topic and
someone mentioned if the the distributors wires arent right it wont send spark or
fuel to the combustion chamber.
Re: (22lbGS-R)
vtec distributor.... hah i was gonna say something to why you posted the same thing twice but i figured to keep my mouth shut
mouab18c1
13
07-23-2011 05:23 PM
si90rex
06-24-2007 05:53 PM
