Honda-Tech, ha.
Old 08-02-2004, 05:17 PM
RicerWTF's Avatar
Default Honda-Tech, ha.
This site sucks ballz. GO RICERS
You have more exhaust decibels than your engine has horsepower.
You have aftermarket FRONT wheels for racing but stock rear wheels.
Your engine makes twice as much horsepower as torque.
17" rims up front, 13" out back on your FWD.
You ever painted your wheels to match the same color of your car.
You put your automatic car in neutral at every stoplight in order to roll it back and try to fool other people into thinking you have a manual transmission
DuPont gave up trying to figure out the shade you were asking for.
Your mod list includes stereo equipment, shifter handle, MOMO steering wheel, PIA driving lights, exhaust tip, but no REAL engine parts.
A chameleon lizard undergoes fewer shade changes than your custom paint scheme.
Your rims and tires are so large, that you have to install the tire / wheel from underneath the car because it simply won't fit in the wheel well going in from the side.
The dealer laughs when you bring your car back in for service under warranty, and you've only had it 6 months...
Your tires / rims stick out from the lip of your car by more than 1."
Your paint job is from the WRONG end of the color spectrum.
You installed spacers on your STOCK wheels and tires to get them to stick out past the fender.
You see cars like yours in a Shriner's Parade for Children and clowns are driving them.
You bring an empty Maxwell House coffee can with you to compare size when you shop for an aftermarket exhaust system.
Your Eclipse GS-T hardtop has a "SPYDER" emblem on the rear...
Your sum knowledge of suspension is: "the more negative camber, the better the handling."
You push your car through the staging lanes. That way, maybe you can break into the 16s by keeping the motor cool between runs.
You add a super tall rear wing, and a hundred pounds of aftermarket ground effects, neon and stereo yet you gut the interior and yank out the rear seat for weight savings.
Your rear wing AND your rear window have a third mount brake light...
The back lighting in the gauges in your A-pillar gauge pod work long before the actual gauges are hooked up.
You cut 4 coil springs and scrape the chassis on the ground. Sparks are cool when you corner at normal traffic speeds!
You have to find a way to drive AROUND speed bumps in a parking lot.
You install clear corner and brake lights.
You install colored bulbs in your aftermarket clear lenses.
You ever put neon on the bottom of your car, and then busted it on the first speed bump you went over.
You painted the UNDERBODY of your car to match
If your rear spoiler is taller then you are.
if you can fit fist **** your exhaust tip
You have more stereo WATTS than engine TORQUE!
If your tailpipe extension is the most expensive mod you’ve done to your engine yet.
Your tailpipe extension fell off during a quarter mile race and you went three tenths of a second faster due to weight savings.
EVERY car in your class has a turbo pushing double digits worth of boost.
You spent $5,000 on the engine and you can not out run a stock Camaro, Firebird, or Mustang
You want the 'wastegate' sound, but don't want to install a turbocharger system.
You think Nitrous Oxide on your Hyundai Sonata puts you in the same performance league as the Chevy Corvette.
The automatic version of your car runs 2 seconds slower in the 1/4mile.
If the 1970 Plymouth Daytona Superbird has a smaller spoiler than your car does.
You think the Del Sol is a sports car...
A torque converter does NOTHING for your car.
You think a deep farty noise = the sound of high performance
If you think that horsepower is far more important than torque
If you have ever claimed that switching to a cone filter has given you more than 5 HP.
If you have ever considered installing more than one set of fog / driving lights.
If you claim that the aftermarket cold air intake system you just installed doubled your horsepower or took 2 or more seconds off of your E/T.
Your baseball cap is always on backwards when you drive (the first sign of mental retardation, wearing your clothes backwards... BE).
You spent all night on the Internet trying to find a company that makes a turbocharger system for your Hyundai...
If you removed your side view mirrors and put them at the TOP of the door / window frame.
If you think the Fugees are 'speed' music.
MOMO is 'absolutely required' to go fast.
Your four cylinder has a dual exhaust system installed.
Your four cylinder has four exhaust pipes ("Hey, one for each cylinder!")
The color of your interior upholstery hurts the cones and rods in other people's eyes.
If you cannot drive your car in snow as the ground effects create a plow effect.
If you have installed driving lights to compensate for headlight blackouts / tape.
If you think that 180 horsepower and 185 lb/ft of torque are impressive for a ‘mildly’ modified engine.
If you have stickers on your car for parts that you could not point out if asked where those parts are installed.
You think pushrods are a bad thing…
Your car has more decals than you do the quarter in seconds.
Every Honda you EVER owned, all the way back to your 1978 Accord was either a V-Tec or a TYPE-R.
You took your rear seat out and gutted your interior for weight savings but you installed 400 pounds of electronics, neon, DVD, Sony, etc.
If you gutted the interior to save weight on a car that you will never take to the track…
You lean your seat so far back when you are driving, that every time you hit a bump, its your back and not your butt that hurts.
You have hydraulics and sixteen switches on a car you claim runs low 10s on the street and corners better than a Porsche.
If you can estimate that your car makes more than 250 HP without ever running it at the track or getting a dyno reading.
You claim that you can get a titanium block for your engine.
If you have ever thought Hyundai and "performance" went hand in hand
If you've ever gone to a parts shop or speed warehouse and asked for a 1" to 6" exhaust adapter...
If you've ever contemplated adding "TYPE-R" stickers to your Sonata…
If you've removed more than 1/2 of the coils from your springs by cutting them yourself ...
If you have more neon lights on your car than a strip club...
You put Kanji on your Ford ZX2, Ford Probe, or Mercury Cougar ...
You own a "TYPE-R" Hyundai or Mazda.
You couldn't afford headlight masking, so you just painted them with flat black Krylon and it's peeling. Badly.
You claim that polishing your intake gave you 5hp.
You own a V-TEC Hyundai or Mazda (especially a V-TEC rotary engined Mazda RX-7)
You have neon INSIDE your car or in your ENGINE compartment
You ever claimed that high gas mileage made your car superior in performance to V8s.
If it takes you 8000rpm to reach 30mph from a dead stop at WOT.
You think yellow plastic interior trim makes your car cool
You spend $500 for a giant hand welded tube for a muffler with the weld marks extremely visible
If you paint your drum brakes to simulate Hi-po calipers
If you install fake hi-po caliper / disc simulators
You have a front wing.
If you lower your car and add ground effects but retain the stock 14inch wheels with disc style wheel covers
If you equate the sound of performance with the sound of a Weed Eater™
If you think bolting a fake muffler to one side to simulate dual exhaust is cool
If you think colored head lights work better
Clear tail lights and turn signals. They’re colored for a REASON!
If you take mom's 4 door Honda accord and do any kind of mod to it
You drive a Ford Escort station wagon with Kanji, wide tires, and Limp Bizkit stickers on the rear hatch
You claim you lost the race because you had a passenger in the car.
You claim how if you went from a roll you would have beat him.
You claim you lost because you missed a shift... and your car is an automatic.
You claim you lost because he must have been on the juice..
Flying past the person who is 10 car lengths in front of you after they have put on their brakes.. and claim a victory.
after losing you flip your opponent off... rev your motor and fail to break the wheels loose even around a corner.
Tell everyone about how you lost the cop because of your "driving skills."
you are a white kid driving an import.. wear baggy pants/hat turned around, walk with a fake limp and end every sentence with "yew know wha I'm sayin? Relate."
Your idea of aiming a handgun is raising your arm over your head, pointing the gun away from you, and then just letting your wrist fall to the side to where the gun is almost sideways ...
drive around in a $20,000 import with $10,000 in mods.. and still live with your parents.
You can relate to every line of the song "Pretty Fly For A White Guy" by the Offspring
you take offense when I say.. "your sister is like your car.. small, tight and hard to get into."
You are a skinny, backwards hat wearing, dog chain wallet, 2 ft wide pants leg, Limp Bizkit looking white boy *** with a badly applied peroxide hair color treatment and temporary rub-on tattoos!
--------------------------------------------------- The following submissions to the list are from Chris (GreenMitsuE1)------------
You've spent more on graphics and decals than you have in gas, for the whole year
You sound like you're going 90, but you're creeping past 25
You upgraded to the "big bore" 2 inch exhaust
You lose 2 mpg by installing a body kit
Your wing is so large that if you go faster than 65, your bumper drags
You think "displacement" is something that happens to homeless people
Yugo's give you a run for the money
You continuously run red lights because they are invisible thru your red window tint
15's are considered HUGE rims
You can reach back and defrost the rear window by hand
You will race anyone, anytime, and already know that you will lose
You think Moby is one of the greatest composers of our time
You spend all your money pimping it out because spending money to make it faster is a waste
Your little sister is the only one impressed with your car
When you win a race, you don't really win, it's just that the other guy felt soooo sorry for you
You think your mom's Corolla is fast
The cross section of your exhaust tip is bigger than the contact patch of your tires
Your aftermarket tach is bigger than your fist
You bought the big *** tach to try to scare off the fast cars
But all it does is let people know how hard you have to push it to exceed the legal speed limit
You rev on school busses
Hell, you rev on people in electric wheelchairs
You buy and install custom rims a pair at a time
YOU REALIZE THAT ALL OF THE ABOVE IS TRUE AND YOU STILL THINK YOU'RE COOL!!!
You've entered a 12 step program called "How to come to terms with your limitations"
The bill of your hat gets caught when you roll the window up
You really want to kick my *** right now
You cut 2" holes in your rear bumper and don't know what they're for
You cut 2" holes in your rear bumper and DO know what they're for
You go to the auto paint store and pick out the most retina burning color you can find
You buy race gas to drop you from 17.02 to 16.9 in the quarter, and then tell all your friends how fast you went
You add a second battery to power all the neon, and the mini disco ball
You add a wing on TOP of your car, 'cause wagons need down force too
You've ever painted bare, raw fiberglass black and said "Look! It's just like carbon fiber!"
You get pimped out props from the mini truck crowd
You still only get dates from high school girls
You actually own a pair of light up glasses from Checker Auto
When you install your super phat wing, you put the pointy ends up
You purchase and install a body kit, one piece at a time
You saw the "Rice Boy" magazine in the back of Sport Compact, and inquired about a subscription
Your brother is pissed cause you stole the muffler off his dirt bike (it was a direct fit!)
Your dad is worried cause you bought a car with less displacement than his lawnmower
Old 08-02-2004, 05:18 PM
unknown0001's Avatar
Default Re: Honda-Tech, ha. (RicerWTF)
» Post reported
The post was sucessfully reported to the moderator
you = teh suck
Old 08-02-2004, 05:21 PM
RicerWTF's Avatar
Default Re: Honda-Tech, ha. (Mr.RHTuner)
NOOOO DON'T DELETE MY TRAIL MEMBERSHIP PLEASE!!! Just spread'n my opinion round. Take or leave it.
Old 08-02-2004, 05:26 PM
kihun_cha's Avatar
lol what he saids was true
but honda-tech aint suck unless you are truly rice.. i hate rice boys too and sometimes when i look at my si it look like cereal box car.. but trust me i run gt's *** bitch.......and dont post up something like that up in here .. just keep it as in ur personal sugestion......
im sure there is more than half of peoples in honda-tech is ricers
but to be tru performance car builder.. you have to go through rice steps to be success..
Old 08-02-2004, 05:30 PM
RicerWTF's Avatar
Default Re: (kihun_cha)
I'm not talkin to you. Don't eavesdrop. Honda-Tech does suck. 99.9% of members are know it all posers who'd rather say your stupid than try to answer your question. So Honda-Tech, you = teh suck
Old 08-02-2004, 05:32 PM
EKRacer's Avatar
So what kinda trash do you drive and what forum do you hang in so we can run up in ther and make childish posts like this one
Old 08-02-2004, 05:37 PM
ABK
ABK's Avatar
Default Re: (RicerWTF)
yeah what do you drive? you are an idiot if you wonna make fun of ricers go to clubsi.com, some saturn or cavalier forum. And so I don't forget go **** yourself.
oh yeah incase I fogot to mention you are an idiot, and suck a dick.
Old 08-02-2004, 05:40 PM
BiziggumS's Avatar
Default Re: (EKRacer)
this guy obviously has nothing else to do but go to honda forums and post blah bullshit about how we are all ricers....hey buddy ur girlfriend that lives all the way across the country from u that is a 46 yr old bald male is online, u better go talk to her!!!!
pdiggitydogg's Avatar
[sigh] another immature person w/ too much time on their hands...
thread reported
Old 08-02-2004, 05:43 PM
RicerWTF's Avatar
Trash? 97 Supra with 2JZ-GTE, SSQV, HKS type1 usa spec, blitz intake, tanabe racing exhaust, full blitz body kit (molded), shaved doors - emblems - and antena, RSP (Royal Sapphire Pearl *blue*) only 21 6 speeds made in this color in 1997, 19"x10" RacingHart C2's in the rear, 19"x9" in the front, Blitz SBC-id/Power meter, 264 cams, Tien HA, springs, HKS downpipe, upgraded twin turbo setup, alpine entertainment system (cd changer, DVD changer, 7" screens), sparco Turino seats with 5pt. harnesses, AEM computer. Forum? Why would I need to join a forum? I don't need any help. I just posted here to post my opinion.
Old 08-02-2004, 05:49 PM
Turbogixxer's Avatar
damn, you make that list up? It is BS.
Y0 y0 y0. I got a skyline y0. turbo upgrade. badass system for the chicks, slammed on 20's y0.
You are a tool. If that is your supra, it is not ****. You suck at life.
AEM computer? sure it is not a Dell?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicerWTF &raquo;</TD></TR><TR><TD CLASS="quote">full blitz body kit (molded), shaved doors - emblems - and antena</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicerWTF &raquo;</TD></TR><TR><TD CLASS="quote">RSP (Royal Sapphire Pearl *blue*) only 21 6 speeds made in this color in 1997</TD></TR></TABLE>
So you take a some what rare car and change what is rare about it (color). Good job.
Old 08-02-2004, 05:50 PM
eL
eL's Avatar
I bet before you made this thread you were thinking this...
"Well I'm a total fucktard moron so let me make a honda-tech.com account and talk **** about hondas. I might feel good afterwards.
IF you have everything you listed thats GREAT but body kits and shaved door handles? Who's the ricer now?
Old 08-02-2004, 05:51 PM
kihun_cha's Avatar
either tru or not .. very good for you man
but some of us in here can't afford such as supra.. if u are one or rich bastard who has supra then go to supra forum and talk **** about hondas.. aiite?
Old 08-02-2004, 05:52 PM
Got Milk's Avatar
Default Re: (turbogixxer)
yea really unless u post pics that " 97 Supra " it just doesnt exist to us and did u kno everyone on honda-tech isnt a ricer thats just like 30% of the site
and dont u mean " Torino " &lt;---- sparco Turino seats with 5pt. harnesses
Old 08-02-2004, 05:53 PM
nimblecivic's Avatar
lmao.....so I'm gonna go on a honda site and bash it, then to cover my *** I'm gonna start thowin' out **** and build a hot car out of nowhere....
I call BULLSHIT........
But, like you, that's just my opinion..... ....have a good evening....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by this tool's profile &raquo;</TD></TR><TR><TD CLASS="quote">Access Level Normal User
Permission Level Restricted Trial User
Full Name HondasSuck
Email Address hondasuck@hondasuck.com
Location NoHondas FL USA
Age 35</TD></TR></TABLE>
You are really 35?
Mid-life crisis?
Old 08-02-2004, 05:54 PM
RicerWTF's Avatar
Default Re:
Haha, listen to your selves. Your all getting angry over this. This is actually amusing. Thanks for the laugh guys.
Old 08-02-2004, 05:55 PM
ABK
ABK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicerWTF &raquo;</TD></TR><TR><TD CLASS="quote">Trash? 97 Supra with 2JZ-GTE, SSQV, HKS type1 usa spec, blitz intake, tanabe racing exhaust, full blitz body kit (molded), shaved doors - emblems - and antena, RSP (Royal Sapphire Pearl *blue*) only 21 6 speeds made in this color in 1997, 19"x10" RacingHart C2's in the rear, 19"x9" in the front, Blitz SBC-id/Power meter, 264 cams, Tien HA, springs, HKS downpipe, upgraded twin turbo setup, alpine entertainment system (cd changer, DVD changer, 7" screens), sparco Turino seats with 5pt. harnesses, AEM computer. Forum? Why would I need to join a forum? I don't need any help. I just posted here to post my opinion. </TD></TR></TABLE>
You might have a fast car, but you are ******. And I bet you paid to get all the **** put on because you don't even know what half of that **** does.
And you go around and call people ricers when you get your door handles shaved and put on a body kit.
Well in either case you are either a young kid that parents bought the car for, then you are big ******. People that I hate. Or you are a grown up ******, in this case you should be ashamed to post this ****, and you are an immature bitch, suck a ****.
Seriously if some will see this *** on the street bitch smack him for me. I would go back to sucking dick because you just made an *** out of yourself.
you are saying that there were only 21 6 speeds made with color in 97? Congrats you just wasted one. BITCH
Got Milk's Avatar
Default Re: Re: (RicerWTF)
lol whose getting madd people are laughing at u that u would actually join a website to express how u feel bout it ( i kno my *** is laughing )
Old 08-02-2004, 05:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RicerWTF &raquo;</TD></TR><TR><TD CLASS="quote">Haha, listen to your selves. Your all getting angry over this. This is actually amusing. Thanks for the laugh guys. </TD></TR></TABLE>
The best part is, we are all laughing at you. You think we get mad over this ****? Trolls do it all the time, you are nothing new or funny. It is sad in a way. Trolls just need a life.
H23AHybridEG's Avatar
Default Re: (Got Milk)
Do you have any imaginary friends that you could describe to us, as well? Why would you even waste your time posting something so stupid? You're an asshat!
you think you're getting anyone here angry?...hell man....I just can't believe you took the time to think up all that ignorance up above......musta been a long day sittin' at home with mom, huh?.....
Cliffs Notes:...Not Angry/Just an Opinion
ABK
ABK's Avatar
Default Re: (ABK)
holy **** you are 35? he defently is in mid-life crisis. Dude if I would ever catch myself doing something like that at that age I would feel so fucken dumb. I could hardly imagine me doing something like that when I was 10 years old. God damn, you need some help.
LMAO, people make fun of him until this tread gets closed, I need something to laugh at.
You just wasted 1hr of your time to register and post this stupid BS, just to get made fun of, lol. Should go back to jerking off maybe?
Old 08-02-2004, 05:58 PM
Got Milk's Avatar
OMG you guys... could u imagine how long he sat in his computer chair to think of all that nonsense LOLOL
Old 08-02-2004, 05:59 PM
Marauder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You are really 35?
Mid-life crisis?</TD></TR></TABLE>
I doubt he's 15.
Quick Reply: Honda-Tech, ha.
