cant get rid of code 22......
Old 08-02-2004, 03:17 PM
japspecjohn's Avatar
Default cant get rid of code 22......
Code 22 for the vtec oil pressure sensor will not go away....Ive done everything wired vtec like 5 times (I know its right ) tryed grounding the sensor a few different ways tried multiple p28s and still code 22...Is it possible that the oil pressure sensor itself is just shot?
japspecjohn is offline
Old 08-02-2004, 03:30 PM
Chiovnidca's Avatar
Default Re: cant get rid of code 22...... (japspecjohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">...Is it possible that the oil pressure sensor itself is just shot? </TD></TR></TABLE>
Yes, you can check it with an ohm meter.
Chiovnidca is offline
Old 08-02-2004, 03:56 PM
Default Re: cant get rid of code 22...... (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you can check it with an ohm meter.</TD></TR></TABLE>
how do I do It?
Old 08-02-2004, 05:14 PM
some body know how I do this? I got a multimeter
Old 08-02-2004, 06:26 PM
bump need info dont wanna short out my ecu or sumthing
Old 08-02-2004, 07:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn &raquo;</TD></TR><TR><TD CLASS="quote">bump need info dont wanna short out my ecu or sumthing </TD></TR></TABLE>
Old 08-03-2004, 03:03 AM
Chiovnidca's Avatar
how do I do It? </TD></TR></TABLE>
It's a switch. It should be closed with the engine off and at idle. It should open as the RPMs increase.(as presure builds up)
Old 08-03-2004, 09:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">It's a switch. It should be closed with the engine off and at idle. It should open as the RPMs increase.(as presure builds up) </TD></TR></TABLE>
should i Test it where the wire meets the ecu?
Old 08-03-2004, 10:07 AM
magicksdc2's Avatar
same problem i have, ive rewired vtec at least twice, i have current and all my grounds are good. im just at a loss, sometimes the light will be off while im driving and then it will pop on at random times. im pretty sure the vtec actually works on my car... but still this code will not go away even after multiple ECU resets.
i was wondering if it could actually be a lack of oil pressure in my situation, because i know i have a valve cover gasket leak and im not sure how low my oil level has gotten. if it was actually low oil pressure, how would i go about diagnosing if i just need to change and fill up (along with replacing that gasket.. already have one im just lazy) or if there is an oil problem somewhere else?
sorry to jack ur thread, but its basically the same problem i have.
magicksdc2 is offline
Old 08-03-2004, 02:04 PM
Chiovnidca's Avatar
should i Test it where the wire meets the ecu?</TD></TR></TABLE>
Disconnect the wires to it and check the switch itself first.
Old 08-03-2004, 02:06 PM
Chiovnidca's Avatar
Default Re: (MGXcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MGXcoupe &raquo;</TD></TR><TR><TD CLASS="quote">
if it was actually low oil pressure, how would i go about diagnosing if </TD></TR></TABLE>
How do you diagnose a possible oil presure problem? Hook up an oil presure gauge.
Old 08-09-2004, 07:01 PM
Default Re: (Chiovnidca)
just a follow up...bad oil pressure sensor thing on the solinoid....replaced and now there is some tec hehe
Old 08-09-2004, 07:16 PM
pynikal's Avatar
Default Re: (japspecjohn)
this might sound stupid but hows you oil level??
pynikal is offline
Old 08-09-2004, 07:17 PM
Default Re: (pynikal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pynikal &raquo;</TD></TR><TR><TD CLASS="quote">this might sound stupid but hows you oil level?? </TD></TR></TABLE>
it was fine it was the vtec oil pressure sensor (the bottom plug on the solinod) that was bad
beoy9
09-30-2006 03:11 PM
hybridEj6
02-10-2004 11:34 AM
stehigs321
01-05-2004 12:28 AM
gargoyle12
11
05-31-2003 06:55 PM
Quick Reply: cant get rid of code 22......
  • Ask a Question
Question Title:
Description:
