'92-'95 Transmission differences?
I've searched, can't find much...
I have a '92 Civic EX (the D16Z6 motor), will any D series transmission from '92+ work (as long as it's hydraulic clutch)? Are there differences between the D series transmissions?
Re: '92-'95 Transmission differences? (handa)
excellent. Thanks.
My stupid transmission won't go into reverse, the gears have been grinding for a while, but I think it finally said "screw you man"
Re: '92-'95 Transmission differences? (Barwick)
Is your clutch fluid topped off? My tranny is a little picky about when it wants to go into reverse as well (z6 tranny) i usually just push in the clutch and run the stick through 1st and 2nd real quick and then it will go right into reverse. My clutch master cylinder is leaking also so I have to keep that topped off until i can fix it or it gets picky as well.
