Me=Retard, tons of air in brake line.. help!
Old 08-03-2004, 03:29 PM
aphex23's Avatar
Default Me=Retard, tons of air in brake line.. help!
Ok, first off, i am a dumb ***, i was going to flush out all the fluid in my brake system.. started with the back right, as should be.. but, as i said, i am a dumb ***, and forgot to close the valve, and went to pumpin away some more.. noticed nothing was coming out, pedal, is floppy as hell, and rememberd, oh hey.. haha, *kicks self in ****** so any way, i grabbed another person, and had them pump, me open and close the valve, but, after like 30 minutes, still nothing came out, a little spurt of air, every once and a while.. but thats it.. how long should i expect this to take! is there an easier way?? any suggestions, would be great!
Old 08-03-2004, 03:35 PM
North_Texas's Avatar
Default Re: Me=Retard, tons of air in brake line.. help! (aphex23)
Well if you got tons of air in there it might take awhile.
Old 08-03-2004, 03:39 PM
aphex23's Avatar
Default Re: Me=Retard, tons of air in brake line.. help! (dixieR3dneck)
should i just keep pumpin and opening it up? or should i move on to the rest? then come back to that one?
Old 08-03-2004, 03:41 PM
antiJDM's Avatar
dude i feel sorry for you thats the only reason im going to help..first im going to ask you if you know how to bleed brakes?
Old 08-03-2004, 03:42 PM
aphex23's Avatar
Default Re: (2thousandcivic)
yeah, im just an idiot and forgot to close it..
Old 08-03-2004, 03:45 PM
soundbomber's Avatar
i don't understand what you were doing, but if you were going to flush everything out, just siphon out the fluid in the master cylinder, open up a bleed valve and pump away. repeat at all 4 corners. after all the fluid is out of your brake system, fill up the m/c with some fluid and pump away to get all the fluid throug the system and have the air sitting right at the bleeder valves. open valves and commence bleeding
edit: keep you eyes on the fluid level in your m/c
antiJDM's Avatar
oh..well then get a friend to help you out..you have a lot of pumpin to do, but look at it this way, you're getting all of the air out and putting new brake fluid in..
Old 08-03-2004, 03:49 PM
aphex23's Avatar
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">just siphon out the fluid in the master cylinder, open up a bleed valve and pump away. repeat at all 4 corners. </TD></TR></TABLE>
so, wait, are you saying i can leave the valve open, and just pump, and air wont get into the lines if i dont close it??
Old 08-03-2004, 03:57 PM
Default Re: (aphex23)
Man go buy a Chiltons book. It talks about how to bleed brakes and everything. I have air in my brakes. But its to damn hot to be messing around with that **** right now.
Old 08-03-2004, 03:58 PM
aphex23's Avatar
i hate this, frickin peice of crap, well, im off to pump the fluid, thanks for the thoughts
well, you have to submerge the tube you have coming from the bleeder valve submerged in a bottle of fluid, so that when you pump, brake fluid goes back in
Old 08-03-2004, 05:05 PM
aphex23's Avatar
holy hell! i have been at it for over an hour now! and there are still bubbles coming up! is this possible!? or could something else be going on here??!
Old 08-03-2004, 06:01 PM
aphex23's Avatar
how plausible is this?? so, i have been at this for over 2 hrs now.. still, air coming out.. is it possible something more is wrong? like, my MC is bad, or something is plugged so that no fluid can get through?? because, this is just insane, there is no way, that much air can be in these small tubes..
Old 08-03-2004, 06:03 PM
antiJDM's Avatar
you keep adding fluid...right? because if you're not..you'll end up pumping air through the lines..
Old 08-03-2004, 06:04 PM
aphex23's Avatar
yeah man, the resevoir is full, hasnt moved AT ALL, no fluid is going through at all... wtf! im going insane!
Old 08-03-2004, 06:28 PM
aphex23's Avatar
blarg, i frickin give up, this makes no sense
Old 08-03-2004, 06:31 PM
ion_four's Avatar
did you let all of the fluid drain our of the MC reservoir? If so, you need to bleed the MC first of all. You can do this (without taking it out) by having someone pump the brakes, while you crack the nut on the MC, just like you would bleed each wheel, closing it when they are letting the pedal lift up.
Maybe you should describe what exactly you are doing, since you might be over-looking something simple. Bleeding brakes does suck.
Old 08-03-2004, 06:35 PM
aphex23's Avatar
Default Re: (ion_four)
well, i have the back right valve open, tube going into a half full bottle of fluid, and am pumping the pedal like a hyper monkey, for 2 hours straight! and still, nothing but little bubbles is all thats coming out!
Old 08-03-2004, 06:41 PM
Jdm*EG's Avatar
o well everyone makes mistakes
Old 08-03-2004, 06:46 PM
murtnabila's Avatar
Default Re: (Jdm*Ek)
here's a trick VACCUM BLEED it.
Old 08-03-2004, 07:06 PM
aphex23's Avatar
Default Re: (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">here's a trick VACCUM BLEED it.</TD></TR></TABLE>
well, wouldnt that be just wonderfull, if i had one, that doesnt exactly help me right now, does it..... In the future WHEN i purchase one, thats what i will do,
and incase for any further suggestions, I never let the resevoir go dry!
thanks!
Old 08-03-2004, 07:27 PM
murtnabila's Avatar
simple but messy, get a BIG pan underneath and some catlitter around
get a friend have him pump and hold
Then while he holding open valve one turn
push on valve where air is coming out from (will work as a one way valve)
then have friend start pumping till you get fluid and no air (you will notice it easily) then have friend push brake in all the way and close valve
then onto next wheel
Old 08-03-2004, 07:34 PM
aphex23's Avatar
well, yes, in theory, this should be very simple, however, something is most defiently not going the way it should be for me.. And I have no clue as to what would cause endless amounts of air to keep coming out of the brake line.. The Res is full, all other valves are closed, it makes no sense.. but, i need ideas..
Old 08-03-2004, 07:35 PM
murtnabila's Avatar
try what I said IT WILL WORK for me atleast. I have emptied my whole system and done it like this...before I bought the vacuum
Old 08-03-2004, 07:53 PM
mnbv's Avatar
buy my helms manual, it tells you how to do it.
Quick Reply: Me=Retard, tons of air in brake line.. help!
