NEED HELP...problem with JDM clock.
Old 08-02-2004, 09:16 PM
XxSOHCDriVerxX's Avatar
Default NEED HELP...problem with JDM clock.
what up everyone. im having problems with my JDM clock. every time i turn on the lights the clock turns off. i was wondering if anyone was having this problem, and if so how did you fix it.
TIA
Henry...
XxSOHCDriVerxX is offline
Old 08-02-2004, 09:18 PM
Jorsher's Avatar
Uhh you sure it's turning completely off? I know with some cars they dim when you turn the lights on. Maybe you hooked it up to a wire you thought was negative but is really a light wire?
Jorsher is offline
Old 08-02-2004, 09:38 PM
Default Re: (Jorsher)
yeah it turns off completely. then i tried the USDM one and it works fine. could it just be the clock itself???
Old 08-02-2004, 09:47 PM
Spade's Avatar
Default Re: (XxSOHCDriVerxX)
How many wires? I wonder....is it just not getting the power for the low level lighting when you turn the lights on.....
Spade is offline
Old 08-02-2004, 09:56 PM
Default Re: (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">How many wires? I wonder....is it just not getting the power for the low level lighting when you turn the lights on.....</TD></TR></TABLE>
i dont know bro. ill check it out tomorrow morning.
Old 08-02-2004, 10:06 PM
Jorsher's Avatar
What's different about JDM clock, are the numbers red?
Jorsher is offline
Old 08-02-2004, 10:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jorsher &raquo;</TD></TR><TR><TD CLASS="quote">What's different about JDM clock, are the numbers red?</TD></TR></TABLE>
it lights up amber
Old 08-03-2004, 12:55 AM
Bump for my brother some one help this foo out
Mikey
Phaze2
HeyMikeyyyy is offline
Old 08-03-2004, 01:42 AM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxSOHCDriVerxX &raquo;</TD></TR><TR><TD CLASS="quote">
i dont know bro. ill check it out tomorrow morning.</TD></TR></TABLE>
let us know how many wires on it...should be 4 (black, yellow, blue, red) on the usdm one....should be the same i'm guessing.
handa is offline
Old 08-03-2004, 10:23 AM
Default Re: (handa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">
let us know how many wires on it...should be 4 (black, yellow, blue, red) on the usdm one....should be the same i'm guessing.</TD></TR></TABLE>
fo sho ill check today after work
Old 08-03-2004, 10:36 AM
ebp 99 si's Avatar
the wiring was the same on my jdm one and my usdm one
if yours is broken i have a jdm one for sale
ebp 99 si is offline
Old 08-03-2004, 10:44 AM
moto27cm's Avatar
Default Re: (ebp 99 si)
I have the exact same problem. The wiring is the same, as far as I can tell. I kinda wrote it off as being a bad unit.
moto27cm is offline
Old 08-03-2004, 01:11 PM
Default Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm &raquo;</TD></TR><TR><TD CLASS="quote">I have the exact same problem. The wiring is the same, as far as I can tell. I kinda wrote it off as being a bad unit.</TD></TR></TABLE>
i think it is a bad unit.
Old 08-03-2004, 01:12 PM
3.3.3's Avatar
thats cuz youve been drinking too much BOBA and youre hallucinating. jk.
3.3.3 is offline
Old 08-03-2004, 01:21 PM
CivicESi's Avatar
Default Re: (3 3 3)
try pushing the flap in at the bottom when it goes dim. Mine is real dim with the lights on, but comes brighter when you do that
CivicESi is offline
Old 08-03-2004, 01:23 PM
handa's Avatar
Default Re: (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">thats cuz youve been drinking too much BOBA and youre hallucinating. jk.</TD></TR></TABLE>
boba is good!
XxSOHCDriVerxX, why not use the usdm one and make amber out of it? i did it to mine and you can't tell the difference between usdm and jdm one.
handa is offline
Old 08-03-2004, 02:41 PM
eg6sir-s's Avatar
Default Re: (handa)
boba is good!
XxSOHCDriVerxX, why not use the usdm one and make amber out of it? i did it to mine and you can't tell the difference between usdm and jdm one.</TD></TR></TABLE>
eg6sir-s is offline
Old 08-03-2004, 02:43 PM
moto27cm's Avatar
Default Re: (eg6si)
why not use the usdm one and make amber out of it? i did it to mine and you can't tell the difference between usdm and jdm one</TD></TR></TABLE>
Because then you have to buy a USDM unit as well.
moto27cm is offline
Old 08-03-2004, 05:06 PM
Default Re: (handa)
boba is good!
ill do that. thanks everyone. LARGE COFFEE SLUSH WITH BOBA OWNS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
swtch7
09-04-2008 04:22 AM
RenegadeB20
06-07-2007 03:08 PM
FrOsTwHiTeDC4
03-13-2006 09:42 AM
fms1day
02-20-2005 02:07 PM
ChiBoy
08-13-2003 04:41 AM
Quick Reply: NEED HELP...problem with JDM clock.
  • Ask a Question
Question Title:
Description:
