b20vtec
b20vtec
i have b20vtec on ek hatch.
what is cheapest route for more power other than the obvious bolt-ons
thinking maybe upgrading fuel delivery system/ignition
would i need to change internals for a super charger at low boost levels?
opinions please
opinions please
Re: b20vtec (maskone909)
Don't bother with ignition mods. Hondas have one of the best factory ignitions there are. Just ask Erik Aguilar and his 9-sec. coupe.
As far as making power beyond basic boltons, most people on this board are gonna really push tuning. Very important. Get a hondata. It's a good investment.
Also, what is your complete current setup, that might help.
Home made turbo I don't know much about the b20, but I'm sure you could get ~9 psi before having to upgrade any of the internals. check out http://www.homemadeturbo.com, a lot of good info there.
Edit: And yes, tune the crap out of it.
Electrician
B20 blocked bored .20 over
84.2mm Wiseco/Endyne 13:1 Pistons
Hastings Moly Rings
Nitrided and Micropolished Crank
Shotpeened rods with ARP bolts
GS-R Oil pump
SRD Porter/Polished B16 head w/ 5-angle Valve Job
ITR Valves
Crower 403 Camshafts
Crower Double Springs w/ Titanium Retainers
3" Intake
Type-R Intake Manifold
SRD Header w/ 1.75" Primaries
RC Engineering 70mm Throttle Body
Skunk2 ECU
STR Fuel Rail
SX Fuel Pump and Regulator
Earls Lines and Fittings
RC Engineering 310cc Injectors
ClutchMasters Stage 4 clutch
SRD 11lb Flywheel
Phantom Grip LSD
Spoon Sports 4.75 Final Drive w/ Hardened 1st gear kit
All this mated to M&H 22x8.5x13 slicks up front.
Total: 12.2 @ 109mph.
This is N/A and, uhmmm, somewhat cheap.
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
Blue Sedan Crew
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">B20 blocked bored .20 over
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
This is N/A and, uhmmm, somewhat cheap.</TD></TR></TABLE>
he said cheapest........., but your **** sounds fun
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
Moderator
Re: (Dimi)
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
where's the tuning??
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
Re: (chad)
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
I wish I could say that stuff was cheap for me.
Hastings Moly Rings
GS-R Oil pump
ITR Valves
3" Intake
Skunk2 ECU
STR Fuel Rail
SRD 11lb Flywheel
Phantom Grip LSD
X2BOARD
08-20-2014 10:09 PM
