Spark plugs and wires worth while on b16a2?
hey guys i got a 00 si, just wondering if you think spark plugs and wires are worth the money for my car? If so which ones? i always hear platinum is a bad conductor, is this true?
Re: Spark plugs and wires worth while on b16a2? (photec2)
Stick with the things you have if you are not experiencing problems...
If you have problems with wires, my only suggestion would be to buy Honda OEM... they are the best for your car... it is proven that NGK blues are not any better than OEM ones and for a fact, OEM wires are the only ones which perform flawlessly in EVERY single test... NGK's are also good but the OEM ones are better...
And for the plugs, I would strongly suggest that you use NGK or Denso according to the specifications in the owners manual...
That's the way I would go, but it is your money and your car so you don't have to take my advice... but if you do, you will thank me in the longterms...
Re: Spark plugs and wires worth while on b16a2? (KKVTi)
NGK plugs and dont replace your wires unless you stock ones are bad because stock ones are the best...if they are good then dont change them unless you are pushing serious HP on the motor
