crank pulley chatter?
Old 08-02-2004, 02:01 PM
geldingmakr's Avatar
Default crank pulley chatter?
i am having a chatter noise that sounds low like the serpintine crank pulley... when i rev the motor the pulley moves away from the motor about an 1/16 of an inch...
i can also move the pulley with a flat head screw driver about an 1/8th of an inch using the a/c pulley as leverage...
is it supposed to move?
the chattering sounded like a water pump, and i stumbled across the crank pulley movement while looking for the source of the noise.
i feel like it is the pulley moving separate from the crank.. but i am
not sure... but the bottom gear for the timing belt is not moving out with it
Modified by geldingmakr at 11:18 AM 8/3/2004
geldingmakr is offline
Old 08-03-2004, 10:18 AM
Default Re: crank pulley chatter? (geldingmakr)
ok i removed the crank bolt and the pulley...
the crank key was gone...
the pulley was ground out to the point you could hardly tell there was a
key way there... and the crank's key-way was larger on the end and got
smaller towards the engine... like a trapezoid.. not a rectangle...
Old 08-03-2004, 10:40 AM
Global Moderator
Jimmy's Avatar
Yeah this has happened to me..
I thought my water pump was going out and it's the pulley that my AC belt goes on..
I had to tighten it up but yet it still keeps doing it sometimes..
goodluck!
Jimmy is offline
Old 08-03-2004, 10:51 AM
same thing happened to me i recommend that u do not keep driving with the crank pulley like that i kept driving and eventually the key chewed up the crank and the pulley
Egone is offline
EJ8_Man
Transmission & Drivetrain
11-21-2015 10:13 PM
therhett17
03-03-2015 04:06 AM
garyc17
10-28-2006 12:05 AM
gerhard
12-13-2004 12:02 PM
suprchrg95
05-17-2004 01:10 PM
Quick Reply: crank pulley chatter?
  • Ask a Question
Question Title:
Description:
