Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes?
B A N N E D
i'm thinking about doing a rear disk brake swap on a 92-95 civic in favor of the 90-93 teg brakes. now, i've been told that as long as i use the brake booster, master cylinder, brake lines, and e-brake cable from the teg, it will bolt up to the 92-95 civic. if i have been told wrong, please let me know.
my other question is this, will the 92-95 civic drum setup(lines, booster, etc) all fit back on the teg(so the car can roll and not sit on jack stands)? if anyone has done this before or know of anyone that has, let me know. thanks!
Re: Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes? (vtecb20coupe)
it will work. you don't have to use the prop valve or MC from the integra.
B A N N E D
Re: Are 90-93 Teg Brakes Interchangeable with 92-95 Civic Brakes? (YumVTEC)
okay, so if i don't use the prop valve or master cylinder, will that cause any stress or problems in braking? so, i should use the brake booster though?
underage
06-09-2005 06:33 PM
vtecb20coupe
02-03-2005 10:54 AM
model x
19
11-03-2002 10:19 PM
