B18 motor making noises wtf should I do
Old 08-03-2004, 03:05 AM
mustninty's Avatar
Default B18 motor making noises wtf should I do
I got a gsr swap in my eg and it has been fine for a few years, but a few weeks ago it starting making a kind of clattering noise at any rpm, over 4 grand. It almost sounds like something is loose in the head. Is it safe for me to just pull the vavle cover off and start torqueing (to spec) everything in sight? Is there anything else I should check when I have the valve cover off? Could this be a sign of needed valve adjustment? Any assistance or ideas welcome.
mustninty is offline
Old 08-03-2004, 03:36 AM
1.8turbolsvtec's Avatar
Default Re: B18 motor making noises wtf should I do (mustninty)
IM SENT
1.8turbolsvtec is offline
Old 08-03-2004, 03:55 AM
mustninty's Avatar
Default Re: B18 motor making noises wtf should I do (1.8turbolsvtec)
I think IM's are blocked here at my job because I'm not getting it. I will either get it when I login at home or just post what you wanted to say.
Old 08-03-2004, 04:26 AM
mosh666's Avatar
thats where i would start, hoping its not my rod bearings
mosh666 is offline
Old 08-03-2004, 12:28 PM
mustninty's Avatar
Default Re: B18 motor making noises wtf should I do (mosh666)
Dude still did not get your IM, and what are and how hard is it to change rod bearings if there toast?
Old 08-03-2004, 01:00 PM
crx_88_si's Avatar
adjust valve lash maybe??
crx_88_si is offline
Old 08-03-2004, 01:04 PM
BeerMan's Avatar
Default Re: B18 motor making noises wtf should I do (crx_88_si)
take off your oil pan and see if pieces of metal fall out
better hope you didn't spin a bearing, it would be a PITA for you, not to mention the cost
BeerMan is offline
blasta510
17
12-19-2011 11:17 AM
JDMEK9R
03-12-2008 02:16 PM
vtecn8ive
10-06-2006 07:14 PM
johnnycivic66
11-24-2004 11:51 PM
danteisme
02-09-2004 09:22 PM
Quick Reply: B18 motor making noises wtf should I do
  • Ask a Question
Question Title:
Description:
