Is engine salvageable
I have a d15 sitting in my driveway has a blown head gasket oil in the head and water in the head is the engine salvagable or just sell off it what i can
Re: Is engine salvageable (Pho Bos)
what's the milage on it? If it's running fine and got okay milage on it someone might pick up the short block for a mini me.
Re: Is engine salvageable (ABK)
its got 122,000 and it has a blown headgasket all I want to know is if the block is salvageable because if so im going to build the bottom end and build up the head and drop it in a shell
Darth ModerVader
If the head gasket is the only thing wrong with it, I don't see any reason why it wouldn't be repairable (and most likely pretty easily too).
Re: Is engine salvageable (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If the head gasket is the only thing wrong with it, I don't see any reason why it wouldn't be repairable (and most likely pretty easily too). </TD></TR></TABLE>
yeah easy if that's all but if the head is warped bad you're fucked.even if you mill the head it could still be messed up. well unless you're a jedi
Squirtin EGsr
17
09-26-2005 09:13 PM
I8ayellowcrayon
18
01-29-2004 11:42 AM
hondacivic4g
11-21-2003 02:15 PM
