b16a1 in 92-95 civic how hard
Re: (Relic1)
are you trying to use everything from the obd0 swap or just the basics? i had a b16a1 in my hatch. was able to use the starter, alternator, etc for the swap. just used an obd1 ecu and distributor.
Re: (UNDER PRESSURE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE »</TD></TR><TR><TD CLASS="quote">All you really need to get is the ecu and dizzy. It's not hard to drop in.</TD></TR></TABLE>
as previously mentioned, a1 uses a cable tranny, so have to deal with that somehow.
New User
Re: (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">
as previously mentioned, a1 uses a cable tranny, so have to deal with that somehow.</TD></TR></TABLE>
hasport makes a kit for that...
http://hasport.com/shop/produc...id=95
not a real problem
not a real problem
I'll be doing mine this weekend. I'm using the B16a1 motor which used to be in my CRX.
If you don't currently have a b16a1, I would save some money and headaches and go with a B16a2 route.
For my conversion:
- Hasport Mounts including cable tranny conversion mount
- OBD1 Distributor
- Chipped P28 ECU
- 99-00 SI Shift Linkage
- Integra Axles
- 4 wire O2 sensor
- Del Sol Dual Core Radiator (optional)
Reusing starter, alternator, fuel injectors.
I'll be doing mine this weekend if you wanna see or participate. IM me.
For my conversion:
- OBD1 Distributor
- Chipped P28 ECU
- Integra Axles
- 4 wire O2 sensor
streetdreams420
08-16-2003 04:51 PM
