people with a stock VX motor
do you hear when your vtec kicks in? i dont have much done to the hatch yet because i dont plan to fix the VX up .. but i was just wondering i never hear vtec kick in and wanted to know if its just due to the "gas saving vtec" crap they used..or if its somthing else?? stupid question i know but its bugging me
thanks
thanks
Re: people with a stock VX motor (.:s h a w n D:.)
You cant hear it, but it does kick in. It will never be as noticeable as a GSR/Si/R. Its VTEC-E, not really designed for performance. I usually noticed a slight pull in 5th when I would gradually accelerate.
Re: people with a stock VX motor (egizzle6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">How would the VX run if you ran it with a p28 or can't you with the wb O2? </TD></TR></TABLE>
Not good, it would run very rich and vtec would engage much higher so you would have even less power....I know it doesn't seem possible . But i would think that if you did run a p28, once vtec would engage you would feel more of a kick b/c it's engaging so much higher and running so restrictive, so the more flow would give off more of a "kick" but still no more power
But I have a bone stock vx,D15z1, with only exhaust (full 2.5" cat back) and I CAN most defiantly hear it when vtec-e engages.
What vtec-e does is you only run on 12 valves (8 intake 4 exhaust) until 3000ish rpm. At that point the remaining 4 exhaust valves open. More exhaust gases will flow, thus more sound.
I guess all of you who say you cannot hear it have never drove in one and are only assuming because of the normal statements about the engine
cute little bastard
Re: people with a stock VX motor (GAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GAccord »</TD></TR><TR><TD CLASS="quote">I cant wait to ditch my vx engine for the h22 shortly. Having no power sucks. </TD></TR></TABLE>
Seriously. But mine broke down so B16 is on its way.
But when i had the vx, i wasnt sure if the vtec-e kicked in at 3400 or at 5000, i would hear a difference in like 7 areas. i think my head was just messing with me. o well
Re: people with a stock VX motor (CivicVX94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 »</TD></TR><TR><TD CLASS="quote">Not good, it would run very rich and vtec would engage much higher so you would have even less power....I know it doesn't seem possible . But i would think that if you did run a p28, once vtec would engage you would feel more of a kick b/c it's engaging so much higher and running so restrictive, so the more flow would give off more of a "kick" but still no more power
I guess all of you who say you cannot hear it have never drove in one and are only assuming because of the normal statements about the engine </TD></TR></TABLE>
this guy knows whats he's talking about. if anything it would be easier to hear it on a VX since the change from a 12 valve to a 16 valve is more drimatic (sp?) than just higher valve lift like in the other vtec engines. I too own a VX and it's quite easy to notice vtec. and really easy to notice going up hill in second.
one time i was low on oil and in a sharp right hand turn the vtec silinoid wasn't getting enough oil so I was revving up past the normal vtec change over mark in the turn with no vtec and then my car strightend out and the oil could reatch the silinoid vtec kicked in at around 5000rpms, it's VERY noticable then. but I don't recomend letting your car go low on oil unless you have a back up engine.
I have a stock VX with i/e with a chipped p28 (i didnt do it bought the car this way) it you can really hear vtec kick it but it kicks it at 5 and I shift at 6500 so kind of point less its still slow as hell.
thatnikkashoD
10-31-2007 07:46 AM
