HELP!!! TRANNY PROBLEMS!!
Old Sep 3, 2004 | 04:51 PM
coupe_hybrid's Avatar
Default HELP!!! TRANNY PROBLEMS!!
I think my tranny is messed up. When I'm In fifth gear while driving the shifter pops out of gear. Does anyone know why this is happening? Is it my tranny because I'm pretty sure it's not the shift linkage.
Old Sep 3, 2004 | 06:00 PM
Default Re: HELP!!! TRANNY PROBLEMS!! (coupe_hybrid)
Bump because I'm desperate for help!!!
Old Sep 3, 2004 | 06:10 PM
2lua's Avatar
how often did that happened? if it happened a lot then you might had bent shift fork.
Old Sep 3, 2004 | 06:30 PM
Default Re: HELP!!! TRANNY PROBLEMS!! (2lua)
It happens every time I'm in fifth gear.
Old Sep 3, 2004 | 06:52 PM
2lua's Avatar
first check to see how tight is your shift boot, and how lose is your shifter bushing. did you change your transy fluid? if all this you done and not help you might have bent the shift fork.
Old Sep 4, 2004 | 10:46 AM
Everything seems tight on the shift linkage I've already changed the tranny fluid also. Where would the bend be at?
Old Sep 8, 2004 | 06:18 AM
morning bump
Old Sep 8, 2004 | 07:29 AM
forcedspeed's Avatar
my suggestion sir is you have to bring it to a shop, bec i think with that kind of symptoms its the sycronizer that messed up you to change the syncronizer for your fifth gear
Old Sep 8, 2004 | 08:22 AM
nocturnaldragon's Avatar
Could be worse you could have no 5th gear at all like me i shift into fifth its like shifting into netural ahh well its only a D-series tranny in my case there a dime a dozen around here im gonna pick up anther one for $20 later today.
Hephro.T
Sep 27, 2016 11:22 PM
B16aCRXSi
20
Nov 7, 2008 11:49 AM
vteg98
Nov 29, 2006 01:31 PM
honcrx91si
Aug 25, 2006 08:24 PM
omg_miiiike
10
Apr 17, 2005 12:35 PM
