just installed clutch loose pedal feel i have bled many times
It was loose to began with after the motor swap and after bleeding it. The clutch is a exeddy organic. After the install no matter how many times i bled it, it flet the same and it never flet this way before. My little brother says the clutch is starting to not grab as hard as it once did. Wedrove it 750 mile b4 any beat downs on the clutch. i dont know what to do, should i try bleeding it again? is the clutch shot? any othe suggestions will be greatly appreciated.
here is my hungery brother
and here is the poor car after the swap
i know they are not relly revlent but it will bring people in
Re: (Andres-eh2)
im a noob but yeh.. could it be ur clutch master cylinder? maybe its internally bleeding.. who knows i might be wrong (messy hatch)--->not honda guru
Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 »</TD></TR><TR><TD CLASS="quote">did you install the disc the right way</TD></TR></TABLE>
Is that even possible? I don't think it's possible, it just simply won't go in.
Do you have freeplay in your pedal? Are you bleeding it right? I would just say run like 1/4 of the bottle thru and see what happens. Also check to see if you are leaking any oil.
gsr camel
09-13-2001 12:05 PM
