Brake problem
Brake problem
My brake is sloppy. When I hit brake my steering wheel shakes. I bleed brake couple of times it gets batter but then it is sloppy again. So I went to local mechanic and he told me my master cylinder is bad. But I just want to make sure. What is symptoms if master cylinder is bad. Is there anything else that could be bad?
thanks guys
thanks guys
Re: Brake problem (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD »</TD></TR><TR><TD CLASS="quote">if the steering wheel shakes...i'd opt to get the rotors turned...and new brake pads...</TD></TR></TABLE>
My car got 38K miles and I check my pad and rotors they looks ok.
Do you think it is because of Master cylinder. Also car takes longer time to stop.
Re: Brake problem (Jaydeep)
if your rotors are warped u probably wont be able to "see" the warpage...u wont know till u get them spinnin on a lathe... as for the MC...i dont see how that could cause teh steering wheel to shake
