rattel at 2500 rpm
rattel at 2500 rpm
I am not sure but it sounds like my cat rattels at 2500 rpm and i checked the bolts and every thing and it does not appear to be lose in any way. has any one ever had a problem like this?
Re: rattel at 2500 rpm (cord18s)
the stuff inside could be breaking up or it could be your muffler. my stock muffler has a hole in it so it rattles on the decel at about 2500 rpm too
well what kinda rattle is it a vibration and does it go away after 2500? because depending on the metal of the exhaust piping and the frame at 2500 they could be matching and thats why u feel that.
do you have a modified exhaust sytem? because maybe the rubber bouncers are out because rubber will keep the vibration down a lot and the bolts the connect the cat should have springs in the to cut down on ratlilng and vibration also.
Re: rattel at 2500 rpm (JayDieM_ej1)
Mine did the same thing at 2500 rpm and between 3k and 3.5k. It was the bottom end of the header and the cat or the b-pipe.
it could be either the insides of the cat or the heat shield of the cat. if it is a heat shield then just get it welded back on to the cat
redsidriver
07-23-2010 12:14 PM
killakoupe
10-27-2006 07:17 PM
