Black Smoke (Searched more info needed)
I know black smoke is running rich but what sensors would be working right to keep it from black smoking. It smokes at idles and just driving.
it is a b16a with a custom MAP sensor hook up and a custom Knock sensor wire.
on the map sensor anyone have suggestions on a good place to put the MAP? I am running a p30 ecu(thats the JDM one right) with the american wiring harnessdo I even need the MAP sensor hooked up sense there is no spot for the motor?
what other sensors would effect the Air/Fuel Mixture.
Re: Black Smoke (mongoliandonuts)
yes you need the map.. try to place it as close to the throttle body as possible and use some vaccuum hose and hook it up to TB vaccuum. As far as where to put it, doesn't really matter just make sure its secure. Zip ties or 3M double-sided sticky tape
