Clutch Squeak Please Help!
I have a squeaking/creaking when I put in the clutch (both with car on and off) it happens around the biting point (middle of clutch release) *where the most pressure is on clutch*
It seems to be coming from the clutch master cylinder: defiantly in engine bay, and likely not the slave. (Slave was replaced with OEM, and Master with Perfection Clutch part. (Bought wrong OEM part for an accord...)
The noise goes away when the car is warm (usually) and is more likely to go away at night and warm.
I tried greasing the CMC, and put anti-seize on the slave.
Please help! Any advice much appreciated.( may give OEM accord CMC if help/wanted-buyer pay shipping)
Thanks!!!
Thanks!!!
Re: Clutch Squeak Please Help!
had the problem, this helped:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-fix-squeaky-clutch-2673423/
but if you're SURE it's the master, then i'd assume it is since it's off-brand.
gianlumase
Honda Civic (2001 - 2005)
05-18-2013 12:39 PM
kirbyMB6
02-26-2011 01:43 PM
