HELP!!!! SMOKING LIKE CRAZY!
hey guys new around here and to the whole JDM world, so I bought a 94' civic dx 5 spd with 205,xxx and spent $500 on it, so was told it would need a new head gasket cause it smoked like a *****, then noticed it was blueish smoke so i ripped the head off and sent the head out to have valve stems and seals and have the valves adjusted, then bought a new head gasket. When you started up the motor (D15B7) the RPMs would jump from 8 to about 22, so bought a new throttle position sensor and installed new plugs and the idle was alot less rough and now not jumping at all, so got the head back 2 days ago, threw on the new head gasket and resintalled the head to factory spec following the instructions meticulously...viola, still ****** smoking, at wits end and would like to see if anyone had any suggestions or hints at why its still smoking (now white smoke)
Re: HELP!!!! SMOKING LIKE CRAZY!
JDM world? Buddy, its a 94 civic DX. It barely has 100 hp. It doesn't even have VTEC. Stop dumping money in that **** box unless you are gonna do a swap and a sleeper build. By sleeper I mean leave the DX badging on it.
I didn't wanna be the one to say it but yeh not only is it not jdm but that engine is a turd not worth putting money into. You could at least buy a d16 long block for 500 and swap out the d15.
Just comb craigslist man I see ls non vtec b18's on there for lije 2 to 400 bucks and little d15's that they can't even give away, if I was going to put money into somthing it would be somthing with more than 95hp
lifesastruggle
Engine Management and Tuning
02-15-2017 03:22 AM
honda luv
06-30-2009 12:05 PM
