Car jerks at about 1500 rpm all gears
hey. i went out for a test drive, i noticed my car jerks at about 1500 rpm, after that, once u get to 2800-3000 it stops. wat cud that be. i think i bled my clutch line properly, cud it be spark plugs bad, but they look good...any ideas? if it has happened to anyone else....
Re: Car jerks at about 1500 rpm all gears
I have the same problem with my car. It will jerk at 1500 rpm on acceleration and deceleration even at idle when I rev at exactly 1500 rpm it will jerk. What we did last time was adjusted the TPS and the jerking problem went away but only at acceleration. I still have a problem with jerking on deceleration the same at 1500 rpm. One of my friend told me that it could still be TPS issue. He recommended me to check the adjustment. It should be 0.5 on close throttle and 4.5 on fully opened throttle. Will try to do an adjustment and will post the result if it fix the problem.
You can to see if it helps.
The HOW would be found here:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-honda-tps-wiring-calibration-thread-2830131/
Hello. My Honda City (type 2 2001 model) also showed a similar issue. I experience the jerking at exact 1500rpm while decelerating. Do you think its an issue with the TPS settings?
I suspect a different enough car that it's not relevant to this over 8 year old thread. Please start your own thread in the Honda "City" forum where other City owners may be of help. And if your issue is TPS all info has already been posted or linked to for you to correlate it to your different vehicle.
