92 civic D15B7 Dies when stoping hard
i have a 92 eg sedan with a d15b7 and it will randomly die when i stop at lights, usually when i stop hard, sometimes i stop normal and i wont even notice it die till i go to take off again and its dead, Any advice? Could my fuel pump be going out? it takes a while to start, and the fuel gauge quit working also. thanks for the input.
Re: 92 civic D15B7 Dies when stoping hard
Does your lights dim when you hit the brake pedal? Could be an electrical ground issue. The othe thought is a vacuum leak.
If there is any sort of vacuum leak in your brake booster then unmetered air could be entering the intake manifold when you apply the brake. Try removing the hose between the booster and the manifold and capping off the manifold fitting, then apply the brake. If you still have the stalling problem then it is probably not vacuum related.
blackhope121
01-15-2008 09:19 PM
94gsxturbo
05-16-2007 05:01 PM
