EK Fuse #44 Shorting Problem
Old 07-26-2013, 12:28 PM
My Honda Blows's Avatar
Default EK Fuse #44 Shorting Problem
Can some help me. I recently got a short on fuse #44 the one side has 12.5v and the other side of the fuse is ground to something on the chassis. I read up and they said to check the fuel pump wire the iacv and fuel injector wire and none of them are shorted out i need help!!!!!! PLEASE the short is causing the #44 fuse to blow when key it on 2nd ignition. And i tested the fuel pump and its good.
Old 07-26-2013, 12:43 PM
Former User's Avatar
Default Re: EK Fuse #44 Shorting Problem
Originally Posted by My Honda Blows
...they said to check the fuel pump wire the iacv and fuel injector wire and none of them are shorted out
The fuel pump is not on the fuse 44 circuit, so eliminate that idea.
What is on the fuse 44 circuit is the main relay, ECU, fuel injectors, and IACV. Buy a box of 15A fuses. Unplug each of these components one at a time to see whether it prevents the fuse from blowing.
Old 07-26-2013, 07:14 PM
What is on the fuse 44 circuit is the main relay, ECU, fuel injectors and IACV. Buy a box of 15A fuses. Unplug each of these components one at a time to see whether it prevents the fuse from blowing.
I checked the fuel injectors and the iacv. And i also switch the ecu with 4 different ones. And when the main relay is unplugged it doesn't blow the fuse and the same for the ecu.
Old 07-26-2013, 07:22 PM
Did you unplug these^?
When fuse 44 does blow, does it only happen when the key is turned to ON(II)?
Old 07-26-2013, 09:21 PM
Yes as soon as the key turns to ON(II) it blows fuse 44 but doesnt blow at ON(I). And still blows with iacv and the injector disconnected is it possible that my key ignition is bad?
Old 07-27-2013, 07:09 AM
What year Civic do you have?
okay
Did you mean injectors (all 4) disconnected rather than injector here^?
No
Old 12-22-2022, 02:12 PM
diorSanchez's Avatar
okay
No
i know it’s been years 😆 but did you ever figure out what the problem was? I got a lsv turbo ek. And it’s blowing fuse #44 as well.
plugger
03-25-2010 09:10 AM
92hybridAccord
04-06-2005 10:09 AM
fastludeh22
12-21-2003 08:50 PM
13BT
09-04-2003 11:27 AM
Blown90hatcH
08-01-2003 04:41 AM
Quick Reply: EK Fuse #44 Shorting Problem
