99 obd1 built civic randomly just shuts off. then wont start for many minutes later
Old 07-24-2013, 03:43 PM
bnmm's Avatar
Default 99 obd1 built civic randomly just shuts off. then wont start for many minutes later
getting aggravated...
99 civic built ls
s300-precision 1000cc high impedience with box.
i tore the harness all down and tucked it. soldered and shrink wrapped everything
i had s300 in a p28. car was running then would just shut off and started misfiring and hated to run. put the same s300 in a 1.5 computer and problem was gone for about 2 3 months. now i start the car. let it idle...then 5 min later just shuts off. cel comes on. no codes. wont start....then let it sit. start it up and the cel comes on but wont flash a code or come up on the laptop!!
why did this happen twice? resistor box tested good..
sounding like an injector driver issue....starting to get tired of this crap..any ideas?
Old 07-25-2013, 01:27 AM
hondadxb20's Avatar
Default Re: 99 obd1 built civic randomly just shuts off. then wont start for many minutes lat
I had the same problem on a 01 Saturn sl the collant temp sensor was going out and would not throw a code
Old 07-25-2013, 01:00 PM
black97civic's Avatar
not real familiar with the s300 but i have heard they have some kind of security setting. Might be something to look into.
Old 07-25-2013, 01:57 PM
carlos8's Avatar
really your injectors are high impendence? Because if so you no need resistor box and this can be your problem, running your saturated inj. at low
impendence ohms.
low imp 2-4 ohms
high imp 12-14 ohms
Old 07-25-2013, 04:56 PM
They would be running at an even higher resistance! Good call. Probably fried your ecu
Old 07-31-2013, 01:14 PM
bnmm's Avatar
no i said it backwards...solved the issue i resoldered my pins and now its fine. pretty weird
Honda5272
01-14-2014 01:28 PM
Poordudes TypeR
13
12-08-2011 07:19 PM
asianspeed
10-11-2006 03:02 PM
SpoolinEK9
09-26-2004 09:59 AM
Quick Reply: 99 obd1 built civic randomly just shuts off. then wont start for many minutes later
