ek hatch brake pedal is siff but no prssure on brake lines !
was good honda tech ? well i took off the passanger brake line cause it got in my way of taken the axel off to drop the tranny and replace the clutch on my cousin 99 civic hatch back . so tryna save the line from snapping on me i unbolted it for a quick 5 mins , i took the axel off and i put the 14mm bolt that holds the line into the caliper, well clutch was replaced , tranny was put back in and harness was clipped back on , i go to test drive the car and all for it to turn on and hear a rattling noise coming from the tranny only wen the car is neutral and then to top things off the car had brakes that were sper delayed in stopping. so i was told by my friend that it could be my fork or throw out bearing that is causing the rattling noise as far as the brakes , i bleed them but still no luck the pedal is now super stiff but the car is very delayed in braking . need help what should i do ??
PINKS
10-18-2007 04:25 PM
PINKS
10-18-2007 06:04 AM
