help with DSM injectors
All the reading I did, nothing makes sense, after all the searching, still no help. I have DSM 450 Inj's how exactly to they plug into the Civic clip? WHat do i need to shave? I also have the complete Fuel Rail from a 1g, the clips, wires etc. Someone help me out!
Re: help with DSM injectors (Louis53123)
well we might be able to help you more if you told us what engine you are putting them on and what year (obd1 or obd2). dsm injectors will need obd1 clips and a resistor box to work with most hondas. you will need to remove the keyway on the dsm injectors fo them to fit in the honda clips.
check this out for some more info on the install.
http://www.homemadeturbo.com/t...tors/
well then you should be all set, if you need more info on the resistor box wiring you could probably look in FAQ or do a quick search and find anymore details you need.
Black R
08-31-2003 03:05 PM
