jdm d15b in 96 civic
Having some problems doing the swap, swapped over most wiring from the y8 I had in there before, but what to do about distributer?? We're using the y8 distr, and it wont match up, and the 15b doesnt have conncetors that will fit in my existing y8 harness. Please help!!
Re: jdm d15b in 96 civic (aho)
Take the D15B dizzy, and swap the connectors on it from the D16Y8 dizzy. You can cut and splice.
The wiring colors match straight up, ie, peach to peach, white to white, all of them match. Just triple check yourself so you know it's right. Dizzy should work perfectly.
I just did this for a guy two weeks ago, so I know it works.
Also, your OBD2 ECU is going to be looking for a CFK sensor or something the D15B doesn't have. At least, you're gonna be throwing a CEL. And the car may or may not be running like ***.
