tapped oil pan?
tapped oil pan?
my local shop wantes like 200+$ to tap my freakin oil pan for my turbo...i think its a redicalous ammount of money so any ideas? seeing as i cant weld im kinda sol....
Go Tigers!
Re: tapped oil pan? (userdead626)
i'd rather tap your moms ***
jk, if you take off your oil pan, find a fitting, and do the drilling, i'm sure they could do i for a lot cheaper.
Re: tapped oil pan? (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned »</TD></TR><TR><TD CLASS="quote">drill+fitting+taping+jbweld= turbo! pan! lol </TD></TR></TABLE>
That's exactly what I did.
I pulled off my pan, lined below where I was going to drill with tape that was hanging off to catch all of the shavings, drilled it out, and JB welded the fitting on.
Just remember to find out where you need to tap it and make sure it's high enough on the pan.
I first put the fitting on and put some JB weld around it. I used a heat gun and hardened that little bit up. I then kept building it up and drying it until it looked kinda like a volcano.
It's been holding up for about 6 months with no problems.
Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">cant you get like a tapping kit at home depot?</TD></TR></TABLE>
You mean like Tap and Die sets? They're like $20, but you just need a drill to tap an oil pan.
Go Tigers!
Re: (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">You mean like Tap and Die sets? They're like $20, but you just need a drill to tap an oil pan.</TD></TR></TABLE>
is that kind of like the tap from the grim reaper? I tap, you die
Re: (userdead626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 »</TD></TR><TR><TD CLASS="quote">anyone have a list of the parts they used?</TD></TR></TABLE>
-Ratchet and your standard assortment of metric sockets.
-Painter's tape
-Small and large drill bit
-JB Weld
-Heat gun (not necessary, just speeds up drying time by a few hours)
-Nut or fitting that fits your return line
-Magic Marker/white out
-Drill
-Painter's tape
-JB Weld
-Drill
