vtec not working
vtec not working
I have a 98 ex coupe and vtec isnt working. Where should i start troubleshooting at? Iv searched but alot of the words used are too technical for me so take it easy on me. Thanks for any help.
Re: vtec not working (AllstockSIke)
Make sure you have a Vtec motor . Other than that anything that has to do with oil pressure, rpm, speed, and temperature could affect your vtec. I had some wiring go bad that went to my vehicle speed sensor once.
How can i find out that i have a vtec motor? I checked online and it says that the model civic i have has vtec. But on my friends civic that has vtec it says it on the motor and not on my motor.
Re: (AllstockSIke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke »</TD></TR><TR><TD CLASS="quote">How can i find out that i have a vtec motor? I checked online and it says that the model civic i have has vtec. But on my friends civic that has vtec it says it on the motor and not on my motor.</TD></TR></TABLE>
look for your engine code (in front of motor, near tranny, under dizzy). for a 98 ex, it should be d16y8 which is a vtec motor. How do you know vtec isn't working? with a stock intake, its hard to tell on a single cam.
Re: (AllstockSIke)
98ex coupes do have vtec.
is your car all stock or has it been modified at all?
does your CEL light come on at all?
And what makes you say your vtec isn't working in the first place???
Are you sure you know how your engine should feel with vtec working?
Yes, i know its not working im not that retarded. And i know how vtec sounds, i heard it before on friends cars. Plus my car isnt stock i have a v2 cold air intake, and skunk catback exhaust. Thanks for anymore help
no CEL ??
also vtec sounds different on different engines,
it's almost inaudible on sohc engines(urs) and it's very loud/noticeable on integras/dohc engines.
Re: (AllstockSIke)
with just an intake, your not gonna be able to hear or feel vtec on a sohc. as long as you have so cels, that your vtec is working. make sure your engine is warmed up, enough oil pressure and oil itself,and your going fast enough (ie over 25 mph). I had to put exhaust, intake, header, cam, just to hear my vtec. and i can barely hear it and i dont even feel it
Re: (Tad)
A cel is when the check engine light comes on. It will throw a code number. Then you need to figure out what is making the check engine light come on. If it is on, I would recommend taking it to auto zone or oreilys and they will read it for you.
Re: (sitinthehall)
why dont you look @ my old vtec thread and see if it helps you, i still have NO VTEC
https://honda-tech.com/zerothread?id=1411682
b16mike
05-13-2005 09:51 PM
