Wheel spec for EG
be professional
Re: Wheel spec for EG (LazJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LazJDM »</TD></TR><TR><TD CLASS="quote">will 15by6.5 4by100 +40 offset fit a 93 cx EG?</TD></TR></TABLE>
Yes, as long as the hub bore is big enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">and what tire size is best.</TD></TR></TABLE>
195/50-15 is closest to the stock overall diameter. 205/50-15 will also work okay.
Re: (waddy41)
not sure but the rims im talking about are the Rota X model (SSR rep)i think they fit EG's not sure.there black with red lip
Re: (waddy41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 »</TD></TR><TR><TD CLASS="quote">u might rub with +40 offset..
try +42.....</TD></TR></TABLE>
on an EG, you'll be fine with 40, even 38 (my old volks). if you go down to 35, then you run into rubbing problems if your car is lowered.
1 Post
Re: Wheel spec for EG (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
205/50-15 will also work okay.</TD></TR></TABLE>
running on this currently... on my cx hatch...
1 Post
Re: Wheel spec for EG (fms1day)
tire profiles also make a difference when choosing a tire to mount on your new wheels. the closest size to stock will depend on your trim level... a 175/70r13 is a bit different than if you have a 185/60r14...anything like 195/50r15, 195/55r15, or 205/50r15 in most tire models will be just find unless the car is super slammed.
GraphiteMW
11
02-19-2007 06:06 PM
