swaping 92 vx hb
swaping 92 vx hb
i got a 92 vx hatch and i want a b16a swap im prolly gunna get the one off hmo but i was wondering exaclty wat i need to do the swap completly im getting the complete swap off hmo but i want to know if i need anything else like hubs, radiator hoses etc or can i keep the stock ones all info is greatly apreaciated...also im having a shop doit but im gunna be there to learn and i wanted to know how long it would take?
cute little bastard
Re: swaping 92 vx hb (codybob)
92-95 EG and Del Sol with 94-2000 GS-R B18C(including Integra Type R) & 93-97 Del Sol Vtec & 99-00 Si B16a2
Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used.
Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year.
ECU: Use ecu that came with the Engine with proper wiring modifications. For those who do not wish to use OBDII ecu's. For the B16a2 Si motor use the JDM P30 Ecu. Other wise you may use a Chipped P28 with the Proper Programing.
Electrical Differences: B18C1 add air intake Bypass wiring. Cx and Vx need to conver to 4 wire o2 sensor. Non Vtec models need to be wired for Vtec solenoid and Vtec Pressure. All models Modify stock harness to fit. add knock sensor if you are not using a Chipped p28 ecu. Hasport Harness for B18C1(GSRmotor) part #EGDX-GSR
Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
Upper Radiator Hose: For Engines using b16a or Type R Head use 94-97 Del Sol Vtec Hose. For Engines with GSR head use 94-up GSR hose
Lower Radiator Hose: 94 Delsol Vtec
Throttle Cable: For Engines with B16a head, use 94 Del Sol Vtec. For Engines with GSR (B18C1) head use 94 GSR. For Engines with Type R head Use 98 Type R
Clutch Hydraulics: Stock
Air Conditioning: 94-95 Del Sol Vtec A/C Bracket
Special Instructions: Using OBDII ECU involves wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an adapter harness will cut down on alot of potential problems.
Special Considerations: US motors are smog legal as long as the motor is from the same year or later. Japanese type R motors are very potent and wiring is relatively easy with ecu adapter harness. The B Series engine swaps into these year vehicles are by far the easiest. there are honda mounts available to bolt those engines directly in and the wiring is by far the simplest. The majority of people opt to put in a B18C, B18B, or 94-95 Del Sol B16a and those bolt in directly using Del Sol Vtec Mounts. the Del Sol mounts are the same as the 94-up Integra mounts with the exception of the A/C bracket.
Re: swaping 92 vx hb (SkoundrelUSA)
wow ther is alot more to it then i was told uhhh i was just told the rear motor mounts and the hubs cuz the motor is a complete swap ummm so if i bought the motor from hmo it would be a drop in and go type thing
cute little bastard
I think as long as he wires the knock and 5-wire to 4-wire correctly you should be set. Just don't forget the little things like oil, coolant, etc.
so 1 i order hmo b16a complete swap get rear motor mount for dohc v-tec and hubs to fit the axels i can send that to the shop and they can do the swap..wat of this trany covers. the hmo comes with a haud. trany and the car is cabble do i need the conversion or will the new tranny just replace it.
D15b Sol
11
06-27-2009 01:37 PM
DC*whore
02-08-2006 10:19 AM
B17swappedEG
05-11-2003 05:53 PM
