Conversion Harness Obd II > OBD I
Well I have crvtec from a OBDII vehical. my vehical is OBD I ,what exactly do I need to get this wired, and where can i get it, ive looked around, did some research but couldnt quite put my figure on it.
thanks in advance
thanks in advance
Will I not need a harness from engine clips to engine clips, i thought teh conversion harness was just for the ECU? does that mean the engine bay clips all match up?
Re: (INCNTRL4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INCNTRL4 »</TD></TR><TR><TD CLASS="quote">Will I not need a harness from engine clips to engine clips, i thought teh conversion harness was just for the ECU? does that mean the engine bay clips all match up?</TD></TR></TABLE>
I plugged a 2000 gsr engine harness into a 95 si hatch and it plugged right in. only needed to wire in the knock sensor.
Re: (RTI)
I'll clear this up...
buy this, the obd2-obd1 harness... http://phearable.net/convharness.html
then buy a P28....or a chipped p28 here... http://phearable.net/chippedecus.html
easy ****.
easy ****.
invisible
11-19-2006 09:23 AM
