escalade headlights on 95 EG
I wanna put escalade HID on my 95 EG, but kinda running into a problem if anyone can help that would be great. i have the headlights and baliss box, but what i dont know what to do is from the baliss the is a 3 pin connector, but i dont have the other side of the connector which would be on the engine bay wiring harness. So how should i go about connecting that to my stock harness in the EG????????????????????? Any help would be appreciate it.
Re: escalade headlights on 95 EG (b18c1cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1cx »</TD></TR><TR><TD CLASS="quote">wtf!?! ohh lord.........</TD></TR></TABLE>
Do you even know what the hell he's asking?
What kind of bulbs are they? I don't know anything about an Escelade, so I don't know if they're reflector type headlights or projector style headlights. You aren't going to just slap the bulbs in your headlights and have them have a decent cutoff.
You're going to need the ballasts, ignitors, and the bulbs. Wiring them up should be fairly easy, but you may want to bump up to a bigger harness, as HIDs can pull upwards of 30amps when they're warming up.
Re: escalade headlights on 95 EG (Ricey McRicerton)
off topic, he wants to put the HID part on hit eg not the whole headlight, if im correct. i hope i am. so spoonracer84eg dont freak out.
Re: escalade headlights on 95 EG (Stu22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu22 »</TD></TR><TR><TD CLASS="quote">baliss</TD></TR></TABLE>
...ballast.
Couldn't resist
...ballast.
Couldn't resist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu22 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Do you have the whole headlight assembly? If so, is it a reflector type housing or a projector? I want to say it's a reflector type assembly, and thats going to be much harder to get a decent cutoff out of.
Re: (Stu22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu22 »</TD></TR><TR><TD CLASS="quote">NO YOU RETARD JUST THE LIGHT BULBS!!!!!!</TD></TR></TABLE>
Listen up ******. Just slapping the bulbs in your stock housing isn't worth a ****.
Re: (Stu22)
Are you ******* serious? You just called Ricey a retard for trying to help you? You do know he can ban your ****** ***, right?
Just so you realize how ironic your comment was, go here to see what it takes for an HID conversion:
https://honda-tech.com/zerothread?id=683685
Also realize that hid kits cost around $300-500. Not quite as simple as buying ******* light bulbs, huh? Before your e-attitude shows up again, tell it buy a brain to accompany it.
Shitface.
Modified by transpar_nt at 8:04 PM 1/5/2006
Shitface.
Re: (transpar_nt)
First off you are the retard in this situtation
so shut your mouth and listen
First off you need to disasemble the headlight
and remove all of the HID components
Projectors (if they are projection style)
Ballasts
Igniters
Then you have to find a way to retofit the projectors (i'm going with projectors because thats what i have) into your headlight housing then wire it back up. Then you need to figure out how to wire the **** up. there are many ways SEARCH!!!
Then you need to stop being ignorant and lazy.
P.S. Ricey isn't the retard, your the one that thought he could just plug in HID bulbs
Modified by Vintech at 9:02 PM 1/5/2006
Ballasts
Igniters
Re: (Vintech)
I suggest NOT doing this yourself. First off you cant spell ballast. 2nd if you think you can just plug them in like that i highly doubt you can wire this up and actually do a retrofit on your EG headlights
Re: (teknoracing)
here's how:
splice the wires from your headlight harness.
now connect those wires together.
take the wires you just connected, and split it into 3 parts to your light bulb. (it doesnt really matter where or in what order you connect it)
you won't see a brighter light than that when you turn the lights on
Re: (ADVAN EG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing »</TD></TR><TR><TD CLASS="quote">I suggest NOT doing this yourself. First off you cant spell ballast. 2nd if you think you can just plug them in like that i highly doubt you can wire this up and actually do a retrofit on your EG headlights</TD></TR></TABLE> agreed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 »</TD></TR><TR><TD CLASS="quote">here's how:
you won't see a brighter light than that when you turn the lights on </TD></TR></TABLE> thats the closest he'll ever get to having HID's
Re: (MysticCivic)
I thought that this was a place where someone could ask a question and get some help but i guess not, cuz its full of low life mother ******* that like to talk **** and have nothin better to do then make fun of people. So no one has to write anymore cuz its not worth my time to talk to stupid people that think they KNOW ALL and look down on the rest of the world. So as a great man once said you all can go *** youselfs!!!!!!!!!!!!
Lata
BITCHES
Lata
BITCHES
Unceasing Measure
Re: (Stu22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu22 »</TD></TR><TR><TD CLASS="quote">I thought that this was a place where someone could ask a question and get some help but i guess not, cuz its full of low life mother ******* that like to talk **** and have nothin better to do then make fun of people. So no one has to write anymore cuz its not worth my time to talk to stupid people that think they KNOW ALL and look down on the rest of the world. So as a great man once said you all can go *** youselfs!!!!!!!!!!!!
Lata
BITCHES</TD></TR></TABLE>
A.) your question made it seem like you were trying to put the Escalade light assemblies on your Civic, not doing what is commonly refered to as "An HID retrofit"
B.) you called one of our moderators a moron.
C.) you obviously have the social skills of a butt-hurt badger, so why the expletive would we help you if all you're going to do is ********** angrilly at your keyboard?
Lata
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">A.) your question made it seem like you were trying to put the Escalade light assemblies on your Civic, not doing what is commonly refered to as "An HID retrofit"
C.) you obviously have the social skills of a butt-hurt badger, so why the expletive would we help you if all you're going to do is ********** angrilly at your keyboard?</TD></TR></TABLE>
pwnd.
Archy - 1
Butthurt badger - 0
pwnd.
Archy - 1
Butthurt badger - 0
Re: (Stu22)
Lata
Actually, people were trying to help you. Ricey asked you a few questions so he could better understand the situation and thereby more fully answer your original post. You promptly replied with:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stu22 »</TD></TR><TR><TD CLASS="quote">NO YOU RETARD JUST THE LIGHT BULBS!!!!!!</TD></TR></TABLE>
Now do you understand? Why should we help you if you're just going to call us names for trying?
...that's what I thought. Now politely get the **** off my internet.
Lata
