ls/vtec need help!!!!!!!!
hello people i need to change my head gasket on my ls/vtec ii tought I would use the one that fits the block but other poeple tell me other things. so what ineed to know is which head gasket to use my set up is b18b block, with b17 head. thanks.
You can buy a cometic head gasket fit for ls vtec it cost extra, but they can be specified for thickness and bore if you like. You can also take an Ls head gasket and dremmel out the dowl pins, or the best thing to do is to get your head modified to fit Ls dowl pins. I imagine in california it can easiliy be done. Here if ft worth I got it done for 100 bucks with a resurface
Re: ls/vtec need help!!!!!!!! (ej1_lsvtec)
good info people i heard that golden eagle makes a head gasket kit if so how much does it cost. thanks for all your help.
