Jackson Racing High Boost System, thoughts ???
Saw this the other day when I was bored, doesn't look bad for a daily driver...pretty simple install comes with hondata and not too expensive ~3000 (not carb exempt I know)
Can't find anything on h-t about the high boost system, I'm not even sure if it uses a more efficient charger for the higher boost ?
Anyone have any real world feedback on this setup ?
http://www.jacksonracing.com/S...38961
Re: Jackson Racing High Boost System, thoughts ??? (Prod)
I would not run that setup on a stock b16. You could but to get the best out of the system I would atleast Change the pistons and rods. And get performance rings. I've only would run between 7-10 lbs max on a stock motor. and this supercharger boosts at 12psi
Re: Jackson Racing High Boost System, thoughts ??? (wushubrian)
wth ? i don't have a b16 ...i'll stop right there
thanks for the useless post anyone have any real information ?
B A N N E D
Re: Jackson Racing High Boost System, thoughts ??? (cambopheonix56)
with a really good tune u can use this charger. After all Jeff Evans tuned a b16 on 14psi stock internals
cylndRPressure
11-11-2010 11:10 AM
