How do i wire up eg sidemarkers to blink with corners?
Does it require removal of the fenders? Also my right turn signal blinks faster than my left. What could be causing this? TIA
Re: How do i wire up eg sidemarkers to blink with corners? (CRISIS)
you dont have to remove your fender. you could but there is really no need. check your fuses or it could just be that one of your bulbs is about to go to ****
Re: How do i wire up eg sidemarkers to blink with corners? (dohcVTECeg2)
Do you know the procedure to make the sidemarkers blink in conjunction with the corners. Like on newer BMW and Mercedes?
tap them into your blinker wires takes all of 2 sec. problem solved.... a bulb is burnt out
Just splice them into your blinker wires or I think passwordjdm sells some type of sidemaker wiring set of some sort! I think there is a DIY thread if your tried searching!
Re: How do i wire up eg sidemarkers to blink with corners? (Slow_CvC99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 »</TD></TR><TR><TD CLASS="quote">tap them into your blinker wires takes all of 2 sec. problem solved.... a bulb is burnt out </TD></TR></TABLE> What!! I thought you had to get a Bimmer or Benz to have the sidemarkers blink with the turn signals??? I guess Ill keep my civic after all /sarcasm
And I thought I sucked at wiring...
Re: How do i wire up eg sidemarkers to blink with corners? (TurboCoop)
Nice. Jag. Another question. Are there actual jdm amber corners for THE 4 DOOR or do i have to get some fake eGay ones?
