driver window off track...how do i?
this is a manual not power window...it has gotten off track some how, and cant seem to figure out how to get the window crank handle off so i can pull the whole door panel off
any help would be appreciated...thanks
Re: driver window off track...how do i? (B18cHatch06)
there is a clip on the inside of the window handle thingy to roll the windows down. You have to pop that off first to get the window handle off.
A spring clip holds the window crank handle in place. Use a small tool with a hook to pull the clip to release it. Put the tool in the side where you grasp the handle.
Edit: ^^^Beat me to it.
Re: driver window off track...how do i? (tech8)
ohhhh yeah tech8! Well there is a v-shaped clip on the inside of the plastic window crank handle. You can ether use a allen key, flat head screw driver,etc, basically anthing that is long and that can fit in the gap between your crank handle and the door panel. So, once you see the clip on the inside. You are going to try to pluck it out and than it should slide right off and than you can take off the plastic window crank handle. BEAT THATTTT!!! hahahaha
Re: driver window off track...how do i? (PinoyxEJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 »</TD></TR><TR><TD CLASS="quote">
Edit: ^^^Beat me to it. </TD></TR></TABLE>
I was just meaning that you posted before I did.
there is a little clip in the handle take that off and then take the panel out and put the window back in track.
Morasso
09-10-2009 05:31 AM
okman16
26
11-09-2003 12:48 PM
Mentat Ghola
01-11-2003 04:47 PM
