eg hatch front on sedan
Hi,
I've been searching around but haven't been able to find anything on the topic. I want to know if the eg hatch front end would fit on the eh sedan? Would they all line up properly?
Thanks
Thanks
Re: eg hatch front on sedan (terrywhite)
no.. you need to customize your fender lines to match an eg hatch bumper
check this pic, my friend's eg sedan eg hatch front bumper conversion
encircled on eg hatch bumper is the pattern for your fenders to match its width..
hth
hth
almost forgot, if you are planning to retain the stock eg sedan corner lights it will be fine.. but if you will use eg hatch corner lights, you need to customize again the fender that will catch the back end portion of the light
Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Very clean sedan... nice front end "conversion" </TD></TR></TABLE>yeah, indeed a very good conversion on that!
Re: (na.civic)
im doing this also. from what im getting you need to cut the fenders in the middle of the tire and weld them together. then use 2dr lights bumper and so on.
things you need for a coupe/hatchback front-end conversion for your sedan:
coupe/hatchback fenders
coupe/hatchback corner lens
coupe/hatchback front bumper
aftermarket lip or stock lip for a coupe/hatchback
<FONT SIZE="3">***NO CUTTING, NO WELDING...>>><FONT COLOR="red">JUST DIRECT BOLT-ON</FONT>***</FONT>
Re: eg hatch front on sedan (eg6sir-s)
+1 for all those materials
but as for my friend's convertion, he used sedan fenders and sedan corner lights.. the rest is customized
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">things you need for a coupe/hatchback front-end conversion for your sedan:
<FONT SIZE="3">***NO CUTTING, NO WELDING...>>><FONT COLOR="red">JUST DIRECT BOLT-ON</FONT>***</FONT></TD></TR></TABLE>
this is good. but its too much work for just wanting the hatch front, so i cut corners.
here's another shot
here's another shot
mj91ef9
06-10-2009 01:48 PM
